The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > installed DCI and problem!! help!
      09-12-2009, 06:54 PM   #1
GOTHP
Drives: 335i e90
I just got installed bms dci yesterday and I loved sound and all that.
but I did some wot pulls at highway.
car shakes like popping
it feels like car is not sucking air properly
does anybody have an idea for this?
I am worried so pls let me know..
      09-12-2009, 07:12 PM   #2
alq80
alq80's Avatar
47
Drives: E92 335i
are the intakes ring clamp thing tightened properly?? you might need to check that!
335i . Montego Blue . HKS Exhaust .
      09-12-2009, 07:14 PM   #3
Delta0311
7478
Drives: 2011 BMW 335xi E92 2016 228xi
but I did some wot pulls at highway today and found that after 90mph
it feels like car is not sucking air no properly
Are you sure you installed it correctly? Did you tigthen all the screws? Is your MAF sensor properly screwed in. I'd double check if I was you. I got a CAI in my car and never had such a problem.
      09-12-2009, 08:01 PM   #4
Terrance28
Terrance28's Avatar
109
Drives: Crimson Red E92
Did you push the aluminum pipes too far into the filter?
Mods list got too long, lets just say more than enough.
      09-12-2009, 08:06 PM   #5
GOTHP
Drives: 335i e90
hmm I tried to check and didn't find any problems yet...
but did some wot again car definately shakes back and force after certain rpm
tmmrw I will take them off and put stock air box in if problem still exist..
does anybody have same problem?
      09-12-2009, 08:25 PM   #6
Delta0311
7478
No my brother has a 335i with a AFE CAI and he also does not have that problem.
      09-12-2009, 09:06 PM   #7
GOTHP
Drives: 335i e90
okay I was running map5 when I had a problem with bms dci. I switched to map3 and tested,had no problem
and switched back to map5 no problem but went into limp mode
so I assume, it will be more likely fuel pump issue
replaced my fuel pump month ago and having a problem again...shit..
      09-13-2009, 02:29 AM   #8
per
Sweden
47
Drives: M3 E92
+1
I belive this is the problem, there are a cone inside the filter that stops the airflow if the pipe has been pushed to far into the filter
M3 E92 ESS VT-625
