Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > sound system question
      09-06-2009, 07:08 PM   #1
i own an e90
chief general
i own an e90's Avatar
72
Drives: e90 white on black manual 6spd
whats up guys...i just recently got my soound system installed from these guys mobile addiction.....i have a 2006 325xi sedan...i know for a fact that my stock system sounds awesome..sounded like i didn't need a system ..but i wanted to boost up the bass so i added one mtx 12" and a rockford fosgate amp...well here's my situation and wanted to know if this was normal ...
one, when they finisshed installing my sound system....the only time my mtx would work if my car is fully turned on ....when the car is off and just turned on the accessory ..my subs sound system (mtx) wouldn't work .. but the interior speakers would still work w/ no bass at all.....so basically, when that happens ...shouldn't my stock bmw system be the same sound when i first bought the car....but all i hear is vocals ......but when my car is fully turned on my subs would work and it works great .....
but my question to u guys ..is this normal?? shouldn't my stock interiors be the same as when the car is purchased from a bmw dealer even though installing a sound system (12" subs and an amp) ...or does it cancel it out the stock amp that we have when installing another sound system..... im new to this ..if u guys could give me a good explanation..that'd be great..maybe these guys did suttin wrong..
      09-06-2009, 07:14 PM   #2
Technic
Technic's Avatar
2288
Drives: 2021 i3S, 2024 i4 M50
Your install shop used the 12V switched power jack as remote, not the proper OEM remote signal (pin 13) at the back of the OEM HU/iDrive.
      09-06-2009, 07:15 PM   #3
i own an e90
chief general
72
what does that do ???? what should they use ??
      09-06-2009, 07:32 PM   #4
kaigoss69
kaigoss69's Avatar
300
Drives: '08 335i
Did you not read Technic's reply?
If you ask me, the way you have it set-up now is not so bad, since running aftermarket amps in ac mode (engine off) repeatedly is not so good for the battery anyway.
      09-06-2009, 07:39 PM   #5
i own an e90
chief general
72
yes that is true..running on engine off w/ the system..is not good....but if i ever wanted to go to an indoor car show..i can't be running my engine inside you know what i mean.... but , ina way...is this a wrong way to do a system ???? PLUS, another thing...what happen to my stock sound .....it sounds like my stock speakers is not putting out any bass from the day i purchased the car after they installed my subs and aftermarket amp.....
is anyone having this problem ....
      09-06-2009, 11:58 PM   #6
Borsig
Borsig's Avatar
Germany
52
Drives: '09 335i ///M-Sport
did they put crossovers on it?
      09-07-2009, 09:56 AM   #7
i own an e90
chief general
72
no crossovers.....
      09-07-2009, 08:55 PM   #8
i own an e90
chief general
72
anybody else counter with this situation
      09-09-2009, 12:19 PM   #9
i own an e90
chief general
72
oh what i just found out what they did was ...they took a channel from my stock amp to power up my aftermarket amp....that is why the stock subs in my car is not working as they should be .....now is that a true statement..
      09-09-2009, 09:48 PM   #10
cassey
cassey's Avatar
Drives: 2008 335i Sedan
I tapped the sub wires to feed the sub amp. Sounds like the shop just cut the wires and disconnected your stock subs. I also used a low voltage trigger for the remote wire. It's triggered by the speaker signal. Whenever my stereo is on, the sub is on too.
2008 Monaco Blue E90 335i 6MT.
Mods: 19" ITC Euro SD's, E46 ZHP shift knob, Matte black grills, Black Lines, 12" Infinity sub.
      09-09-2009, 10:08 PM   #11
i own an e90
chief general
72
hmMMm good point buddy .... wel ima have this other shop check it out for me ...thanks for the heads up though
      09-13-2009, 07:36 PM   #12
kaigoss69
kaigoss69's Avatar
300
Drives: '08 335i
I did not think this was possible to do. I am not an electrical freak but you may be overloading the OEM amp that way! Also, I think it is generally not a good idea to have different speakers playing the same frequencies, the word "cancellation" comes to mind.
      09-13-2009, 07:52 PM   #13
cassey
cassey's Avatar
How else do you feed an audio signal into the sub amp? I tapped the subwoofer outputs with a Hi/Lo converter to the new amp. I doubt its putting an excessive load on the stock amp. If you try to add additional speeakers directly to the stock amp, then you're adding additonal load to the stock amp.
The left and right speakers play the same frequencies. Are you getting sound cancellation from them? They would only cancel each other out if they were out of phase from each other.
      09-13-2009, 11:18 PM   #14
kaigoss69
kaigoss69's Avatar
300
Drives: '08 335i
Sorry, wasn't trying to be critical. As long as you're happy...
