ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      08-23-2009, 06:01 PM   #1
polaxgr
polaxgr's Avatar
12
Drives: with a highly modded iphone
Not Loving My Brakes
Hey guys...to cut a long story short.. my brakes suck after 4-5 brakes at 200+... anyways do u have any suggestions for braking system ? 6 pistons ? which ones ? cost ? or just change my pistons and leave the rest same ?
      08-23-2009, 10:28 PM   #2
jragan
Imola Lover
jragan's Avatar
26
Drives: 2007 Imola Red M Coupe
You're going to need to define what you mean by "my brakes suck after..." Is your pedal "mushy"? Is the pedal firm but you're just not stopping? What?
His: RIP-"Ruby" E86 ///M Coupe: Pics Track Pics Short Vids Long Vids
Hers: 997-1 C4S: Pics
      08-24-2009, 09:23 AM   #3
polaxgr
polaxgr's Avatar
12
i mean after 4-5 heavy braking on high speed or coming down from a mountain...they are unable to work good...they over heat i dont know...many ppl suggested me to change to ferodo ds 25000 and motul rbf 600...i hear some shacking and noise also from brakes
      08-24-2009, 11:19 AM   #4
jragan
Imola Lover
jragan's Avatar
26
Is the pedal mushy or is the pedal firm but the car just doesn't stop?
      08-24-2009, 04:08 PM   #5
polaxgr
polaxgr's Avatar
12
mushy...and i hear a noise and i feel a tremble..
      08-24-2009, 05:03 PM   #6
jragan
Imola Lover
jragan's Avatar
26
You've likely boiled your brake fluid and warped your rotors. Most likely due to prolonged and improper braking by "riding the brakes". If you're going downhill you should be engine braking and/or getting on the brakes hard and then getting right back off of them.
      08-24-2009, 06:33 PM   #7
polaxgr
polaxgr's Avatar
12
yes i know :-| the car isnt new, i mean i baught it used. so what do u think i should do ? change brake pedals and what else ?
      08-24-2009, 07:09 PM   #8
JCz04Bimmer
JCz04Bimmer's Avatar
32
Drives: 06 Z4MC
Change the brake pedals? No. The pedal itself almost certainly has nothing to do with what you're describing.
You need to do a brake fluid flush. I recommend Motul 600. It's worth the extra money. And if you're feeling a vibration under braking, you've either warped the rotors (doubtful, actually) or you have deposited brake pad material on the rotor. This happens when you get the brakes very hot and then you stand on the brakes while stopped. Either way, I'd change the rotors too.
|www.onehotlap.com|Real People|Real Cars|
      08-29-2009, 09:24 AM   #9
wildag
///M'n it Up
wildag's Avatar
17
Drives: '06 ///M Roadster
The real answer here is, learn to down shift and not use your brakes when going down hill. Your car has a pretty good brake system. If you use it correctly, it will more than suffice for your needs.
zpost
