Cheap engineered Air scoops
07-30-2009, 11:38 AM | #1 |
251
Rep 840
Drives: BMW F13 M6 // BMW F22 M235i
I was bored for the past 2 days and decided to see if I could make some ram air scoops for my Beemer. I may have posted in wrong section... mods feel free.
Sheet metal from Home Depot($5.60, plus some metal cutting scissors,$14.00) My reference for the design...Thanks aFe This is some paper cut out I made of what the air scoop might look like. I work well with physical models that I can look at (Brainstorming). Tools!! The pliers are used to bend the metal. The sheet metal was pretty tough to bend. Prototype. I used the hammer to flatten out the curves. The semi-finished product. I still have to adhere the side walls. I'll use metal "super strength" Epoxy adhesive. Retrofit screw holes that will fit the top OEM air scoop. I test fitted the air scoops more then 10 times and made adjustments so it would fit as snug as possible. I wore gloves most of the time but still managed to cut myself. hah. After I bond the side walls I'm gonna install them and do some test runs. They should hold up to my predictions. I'm thinking of painting them Yellow. I'll post the finished product soon!. I decided to paint them black. Here's one of the air scoops installed. Front view. I have a short video that I'll post proving that air scoops DO work. I just need help posting the video. it's from You tube.
BMW FTW!
"Power is nothing without Control" - Pirelli. Last edited by Nutballa; 07-31-2009 at 10:36 PM.. |
07-30-2009, 05:50 PM | #2 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
I did the same thing, pretty easy, and well worth saving the cost of what they are to buy already made.
One tip, I used 3M double sided foam tape (same stuff to stick on spoilers and such), and they have held on since I installed about a year ago...and I have hit 150+mph more times then I should admit. Oh and I painted mine black. |
07-30-2009, 08:28 PM | #5 |
31
Rep 324
Drives: Sparkling Graphite 2007 335xi
Brilliant!
1987 Black on Black Mitsubishi Starion ESiR
2007 Sparkling Graphite 335xi |
07-30-2009, 08:49 PM | #6 |
122
Rep 6,594
http://www.boston-bmwcca.org/referen...er-Beemer.aspx
Cool idea though, looking forward to seeing how they look on your car.
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
07-31-2009, 12:22 AM | #8 | |
251
Rep 840
BMW FTW!
"Power is nothing without Control" - Pirelli. |
07-31-2009, 12:23 AM | #9 |
251
Rep 840
Not yep, I'll post once I install them. The bond is still curing...
BMW FTW!
07-31-2009, 12:31 AM | #10 |
251
Rep 840
This adhesive is very strong! I had to use a drill to sand down the sides. I'll install them later on today. I cut them and made them a half inch shorted in the front
BMW FTW!
"Power is nothing without Control" - Pirelli. Last edited by Nutballa; 07-31-2009 at 12:53 AM.. |
07-31-2009, 12:33 AM | #11 | |
251
Rep 840
haha, my bad. Beemers stand for moto's. I forget.
BMW FTW!
07-31-2009, 12:41 AM | #12 |
251
Rep 840
haha. Once, I opened up my intake where the filter is and found some big ass moth, lol. This was before I made the scoops, so idk how it got in there.
BMW FTW!
07-31-2009, 10:29 AM | #13 |
251
Rep 840
I took the car out for a drive this morning and did some pulls on a long stretch of road with 335i auto with paddle shifters. I noticed improved throttle response with the help of AFe's high-flow filter installed. IN addition, when I change gears the transmission seems smoother. This was noticeable around 50-100MPH. However, performance may have improved in a wider range of speeds. I only drove it for 15 minutes, plus i got freaked out when I flew past some parked cops.
BMW FTW!
07-31-2009, 10:46 AM | #16 |
Modder Raider
756
Rep 8,633
Drives: M3
I would definitely paint those!
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
07-31-2009, 11:30 AM | #17 |
38
Rep 565
Nice going. I really laughed when I saw those thick leather gloves and when I saw the cut with the plaster I nearly peed my pants hehehe. It would be cool if you could create a real size pdf with the cutout dimension for all the DIY dudes.
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63 |
07-31-2009, 10:36 PM | #18 |
251
Rep 840
Yeah, they look ugly without paint. I decided to paint them black.
BMW FTW!
07-31-2009, 11:08 PM | #19 | |
185
Rep 1,640
08-01-2009, 08:48 PM | #20 |
hi
129
Rep 1,140
nice vid i always thought my scoops helped at higher speeds.
2022 M Sport G05
Jb4, CTS catless dp, M performance exhaust, bms intake, IND goodies, Maxton kit |
08-03-2009, 05:16 AM | #21 | |
307
Rep 5,175
08-03-2009, 10:20 AM | #22 |
king of the hills
92
Rep 2,915
The technically don't cover up the radiator, because the slant at the back of the scoops will still allow airflow over the top portion of the radiator.
