Alpina B3 has different AT software????
07-27-2009, 01:45 PM | #1 | |
129
Rep 1,629
I was reading through TopGear's review of the Alpina B3 and ran accross this snippet:
07-27-2009, 01:57 PM | #2 |
47
Rep 437
actually.. i wish there were companies that optimized the auto trannies with cooling etc kinda like the g37 and 370z autos
http://www.gtmotorsports.com/product...cat=262&page=1 the tranny can run over 600whp!! i wish that was an option for us.. or at least becomes one when we see more big turbo upgrades..
335i . Montego Blue . HKS Exhaust .
07-27-2009, 02:06 PM | #3 | |
263
Rep 2,559
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
07-27-2009, 02:08 PM | #4 |
Back in a BMW
205
Rep 5,208
more info
Ian
07-27-2009, 02:33 PM | #5 | |
Rep 59
BTW how's your oil-cooler performing???
Vishnu-Quaife-AR-Helix-BMS-Stett-Tial-McKinney
07-27-2009, 03:10 PM | #6 | |
129
Rep 1,629
07-27-2009, 03:19 PM | #8 |
38
Rep 565
I have had various versions of gearbox software. I tried the Alpina file but found the kick down was far too sensitive for a car with a tune.
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63 |
07-27-2009, 04:11 PM | #9 |
189
Rep 5,046
07-27-2009, 04:15 PM | #10 | |
263
Rep 2,559
As to the oil cooler, it works very well - last week-end I had several stretches where I could run above 220 km/h for some minutes, and where before the oil heated up to around 130 degrees Celsius. Now I can't even bring it to 120. It will be tested some more in three weeks on the Nürburgring where I'll be with some great guys from the UK forum here. Alpina_B3_Lux
07-27-2009, 05:33 PM | #11 |
38
Rep 565
I cant really say I noticed a difference in the shift speed. There where too many parameters changed at the time for me to be able to comment on that. The main reason we used it was that we where learning about torque limitation faults and engine over speed that was caused by the gearbox software. My tuner then managed to break down different stuff on the gearbox software and now I have something slightly different. The throttle sensitivity to kickdown sensitivity was definitely felt.
Another thing at the time was there was DME software being passed around that was called in a certain circle of tuners as the Alpina file. The power graph of the cars is identical to the Dinan file which was released after that. It also give the same coding fault as the Dinan file.
09 C63 |
07-27-2009, 06:32 PM | #14 |
189
Rep 5,046
I've reached the point that I never use it. It seems to do a great job in regular D but once its in DS it lags and takes for ever to downshift, if it even does. I find it useless. I also find that since the power drops just over 6k, the cars a little peppier if the peddle isn't fully depressed. That way it doesnt run to red line before shifting.
07-28-2009, 01:55 AM | #16 |
189
Rep 5,046
Absolutely. Not that I dont think it shifts fast enough as is. But I'd love it to be just a little bit faster. It would be awesome if we could choose shift points. But thats just dreaming.
07-28-2009, 04:11 AM | #18 | |
Moderator
322
Rep 5,493
I've driven the member's car with the Alpina software, and can report that it does indeed change gears faster than a regular ZF transmission. There was absolutely no additional aggression in kickdown either when combined with a very advanced flash remap - it was very smooth both ways, just noticeably quicker. The change points are also slightly higher in the rev range, meaning that the next gear falls right in the meaty part of the torque band. Oh and Mr B3_Lux - see you in less than three weeks !!!!
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
07-28-2009, 04:12 AM | #19 |
Moderator
322
Rep 5,493
Nope, it uses the ZF6HP19TU just like the regular 335i
07-28-2009, 05:00 AM | #20 | |
620
Rep 2,013
If this was an OEM software then I could try to find the correct file in the Progman package and flash my gearbox... |
07-28-2009, 05:52 AM | #21 |
ocasionally in crisis
52
Rep 2,358
i could be wrong, but life is not usually that easy
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
07-28-2009, 06:00 AM | #22 |
620
Rep 2,013
I know it may require some additional coding or something else, but if somebody had it done on his 335i then I think I could do it.
I have coded and flashed my car many times, but I simply need more info on this, e.g. Alpina B3 gearbox part number. |
