When Testing an Intake, Why are People Dynoing with the Hood Open?
07-25-2009, 05:27 PM | #1 |
Modder Raider
753
Rep 8,633
Drives: M3
This has always made me wonder.
Of course, if there is a filter or 2 filters just sitting in the engine compartment, then of course the intake is going to show more gains if a fan is blowing air on the intake while dynoing. Better yet, you might as well get some dry ice and put it by the filters so the numbers will get even higher! It doesn't matter if the hood is open or shut with the stock air box because the engine isn't going to get any more air by the hood being open. So, I have a word of advice for people that really want to prove if an intake works. Dyno with the hood closed 3 times with the stock intake. Then dyno with the hood closed 3 times with the aftermarket intake. Or, vice versa. I don't care which is done first just as long as there is enough cool down between the switch over. If i see an increase with the DCIs or other intakes by using the above methods, then I will be sold. Becuase, I don't know about you guys, but I drive around with my hood closed. Don't you?
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
07-25-2009, 05:44 PM | #3 |
ASR Turbos+LSD+Meth= :D
73
Rep 1,517
Drives: E92 335i
i will be testing a prototype closed box system soon mr. 5. i'll post a review for the members here as well. i'll also dyno above like you said however being a "closed system" like stock, i doubt anything will change.
2007 335i Coupe Mods: Check the Garage |
07-25-2009, 05:49 PM | #5 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
On the road at say 50mph, underhood temps aren't much higher than ambient. On a stationary dyno, with tiny fans, and no low pressure zone under the car, underhood temps are sky high (over 200f with hood closed). That's we they are better left open. And even with a fan blowing hot stagnant air off the top of the engine. It's just closer to real world conditions. If you are testing with a massive windtunnel fan, that's another story.
Shiv |
07-25-2009, 05:51 PM | #6 |
27
Rep 1,410
it is hard to do... I tried it once with hood closed and the SSTT went into overtemp bypass before the 1st pull was done. You really have to have a 140 mph wind-tunnel to do it with the hood closed to simulate real road conditions. It was about 95 and high humidity that day also. I do agree if you are doing open element filter/s intakes with the hood open it is not going to be accurate.
07-25-2009, 05:54 PM | #7 |
189
Rep 5,046
Even with a fan blowing into the engine compartment I think you'd be pushing more, cooler air through the engine compartment at 65mph than a fans going to blow.
07-25-2009, 06:10 PM | #8 | ||
Modder Raider
753
Rep 8,633
Drives: M3
Some dyno shops have 70 mph fans. Also, most people are stop and go driving and doing less than 50 most of the time. Quote:
Let's say that's true, then going to the drag strip is going to hurt performance when launching? what about going to the track? I'll guarantee that the under hood temps are much much hotter than ambient.
07-25-2009, 06:32 PM | #9 | |
Just some guy
49
Rep 1,531
hood test it would be a great starting point to say low range pull. But to really see the full effects u either need a wind tunnel simulator or 3 high power fans. Cuz i think the intake would only be beneficial above 100mph over the stock one. Thats why u dont see any difference in drag times of cars with or without DCI or CAI
2008 BMW 335i/Sedan/Alpine White/Terra/Steptronic/Premium Package/Sports package/Comfort Access/USB/Sirius
07-25-2009, 07:14 PM | #10 | |
61
Rep 939
07-25-2009, 07:17 PM | #11 |
Modder Raider
753
Rep 8,633
Drives: M3
Still OEM. I'm currently testing out the AFE drop in with some other things.
07-25-2009, 07:21 PM | #12 |
61
Rep 939
07-25-2009, 08:39 PM | #13 | |
Modder Raider
753
Rep 8,633
Drives: M3
If someone likes an intake because of the sound then great, but I'm still not convinced that they add that much power (if any).
07-26-2009, 12:21 AM | #14 |
اوليسيس
196
Rep 4,678
think it depends on how much power you are running. at some point that airbox has to choke the engine.
07-26-2009, 01:12 AM | #15 | |
Ballin' out of control.
520
Rep 1,289
Run 004 is my baseline, 100% stock. 7/18/2009 1:20:42 PM Run Type: RO Run Conditions: 86.41 F, 30.26 in-Hg, Humidity: 30%, STD: 1.01 Run 008 is with a BMS DCI and a Stett Performance charge pipe w/Tial BOV. 7/19/2009 4:20:12 PM Run Type: RO Run Conditions: 86.28 F, 30.27 in-Hg, Humidity: 32%, STD: 1.01
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
07-26-2009, 04:08 AM | #16 | |
BMW Client Advisor
1000
Rep 3,526
07-26-2009, 04:49 AM | #17 | |
520
Rep 1,289
Immediately after installing the intake/charge pipe/BOV, without adaptation, it appeared that throttle response had been greatly improved. I attribute that to the intake.
07-26-2009, 10:13 AM | #20 | |
Modder Raider
753
Rep 8,633
Drives: M3
I just want to see runs with the hood closed.
07-26-2009, 11:04 AM | #21 |
Just some guy
49
Rep 1,531
Until way more power and bigger turbos I think it is adequate. But what do I know. My car feels fast as can be with just a drop in. It never feels like its being choked and I'm runnin high boost
07-26-2009, 11:19 AM | #22 |
139
Rep 717
I just really don't believe dynoing with the hood close is ever going to simulate real world driving on the road. I think that as you have air flowing through the engine compartment is much different in real driving than fans blowing on it. I think dynoing with the hood open is a fair comparaison to realworld driving based on air intake temps at the filters themselves. IF you dyno with the hood closed you really heat soaking under the hood even with fans blowing its not the same as real world driving.
