Procede adaptation?
07-24-2009, 06:36 AM | #1 |
Cruiser
16
Rep 106
Procede adaptation?
Just changed from Dinan 3 to Procede and i have to say that i am not too impressed. What my but dyno can say is that there is at least 20-30hp less now especially low end torque is missing. Is there some kind of adaptation period for Procede to work properly if not does any body have an idea what could be wrong, i have drive 150 miles now with the Procede.
(edit) I installed the procede as it arrived: Stage 3 and it is Rev.II CANbus, it arrived a month ago so it is loaded with the latest maps at the time. My other mods are: ar catted dp:s, injen intake, dinan exhaust, dinan oc, dinan ic, dinan flywheel, rr occ. Last edited by Ramppo; 07-24-2009 at 09:51 AM.. |
07-24-2009, 07:33 AM | #2 |
161
Rep 7,377
what Stage are you running? how much are you boosting? Should be plenty 150 miles adaptation.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
07-24-2009, 07:40 AM | #3 |
274
Rep 6,510
What map are you running? Did you make sure its not in valet mode?
Install the user software, and upload the newest maps and firmware. http://www.vishnutuningforum.com/for...read.php?t=990 |
07-24-2009, 08:44 AM | #4 |
164
Rep 2,875
+1, make sure all the firmware/software are up to date. Even the Procede reader. Then upload the latest map, which is 7-14 I believe.
Do you have the Rev.I or Rev.II? Do you have any mods besides the tune? If so, make sure you're running the appropriate map! Enjoy
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
07-24-2009, 10:37 AM | #5 |
93
Rep 2,339
I'll give you $400 for it.
What do I know? I'm insane.
07-24-2009, 10:55 AM | #6 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
If it came from us, it should already be preprogrammed. No need to update anything unless u want to update to the latest maps that were posted last week. However, if you asked us to preload the procede so that it runs in valet mode upon start-up, it will do just that. It should be much stronger than your previous tune when. Do u have a boost gauge?
Shiv |
07-24-2009, 12:44 PM | #7 |
134
Rep 3,132
Why not try a lower map? Stage 2 ran slower for me without catless DPs than Stage 1. Stage 3 with catteds might be doing the same for you.
2018 R35 GT-R Cicio800 | 2007 E92 335i - RB Turbos, TC Kline DA Coils, HPA M3 Suspension, Quaife LSD, Stoptech BBK, JB4, FuelIT, AR Downpipes, RDSport Quads, Stett OC, Helix IC, Volk TE-37, Vorsteiner V-35, OSS Headlights | Retired - 2015 F82 M4
07-24-2009, 12:49 PM | #8 |
Night Sh1ft
458
Rep 3,079
Drives: F95 X5MC LCI
make sure you switch out of valet if you havent done so ...youll know when its on
"Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson |
07-24-2009, 01:45 PM | #10 |
Cruiser
16
Rep 106
Shiv:
Unfortunately i dont have a boost gauge but i`am right now learning how to data log isn`t that one way to see max boost? Yes bought this straight from you and i don`t recall to ask you to preload valet mode upon start-up. I just gave you my cars mods and and the it arrived as stage 3. |
07-24-2009, 02:34 PM | #14 |
Cruiser
16
Rep 106
Thanks for all the advises, i`ll just go and check the valet mode and data log it if i can and tell you the out come.
I think i`am not giveing up this easy so it`s not for sale... yet. |
07-24-2009, 03:55 PM | #15 |
Cruiser
16
Rep 106
Every thing went fine untill i tried to go online with Procede reader it said unable to connect to port13 (which is my port) all the connections are ok the cables driver is installed my laptpo finds the cable it just wont go online? so i can not check if its on valet mode or data log it
07-24-2009, 04:09 PM | #16 | |
93
Rep 2,339
07-24-2009, 04:10 PM | #17 |
164
Rep 2,875
Close the procede reader and open it again. Now try going online with the procede, it should work if you're 100% positive that you've got the right port #.
07-24-2009, 04:37 PM | #18 | |
1737
Rep 17,960
Drives: A Lot
Another way to make sure that you are not in valet mode is by pressing the "ON" button on your remote keyfob. You should see the CEL flash twice (for map 2). Drive it and see if your Dinan flash is still faster. Shiv |
07-24-2009, 04:38 PM | #19 | |
863
Rep 2,897
Stage III is Catless |
07-24-2009, 04:40 PM | #20 |
103
Rep 2,626
I'd really invest in a boost gauge to troubleshoot... Since you already have dual cones, it will take two minutes (no joke) to install, and you can just run it through the window into the cabin to troubleshoot, then remove it.
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me. -ChuckV |
07-24-2009, 04:42 PM | #21 |
274
Rep 6,510
+1 on the boost gauge... you can INSTANTLY see what your tune is doing
07-24-2009, 08:39 PM | #22 |
127
Rep 2,224
it clearly isn't installed or setup correctly. if you can see the maps change through the engine light on the dash that is a good start. apart from that, you need to log in to the unit and set it up.
