Went to the track with JB+, no gain?
07-24-2009, 12:08 AM | #1 |
Rep 19
I took my wifes 09' 4 door auto to the track for the first time. Car had about 750 miles on it at the time. I did about 3 passes bone stock. Grudge racing, so no times. Each pass was right at about 100mph. I then installed the JB+ set at 2 notches above default, not sure what percentage that would be (how much does each notch represent?). I took the car out on the road and did about 6 or 8 wide open runs from about 30-120 to hopefully let it adapt. I then made 4 or 5 more passes. Never topped 100mph. The car felt stronger up to about 70 and then seemed to nose over to 100mph. Air temp was about 90 with a DA over 6k feet. Was this not enough time for the car to adapt? Is it possible that the intercooler was heat soaking from the added boost and heat causing it to pull timing? I scanned the car and have no faults stored. Any ideas? Thanks.
07-24-2009, 12:22 AM | #2 |
102
Rep 919
You should just set it to 100% and do the solenoid bypass. Also 6-8 WOT runs is not enough time for it to adapt I did more WOT throttle runs than that every day for about 3 days before it really seemed to have settled in.. The 2nd day was the biggest difference though.
07-24-2009, 07:41 AM | #3 | |
Joint Chiefs of Staff
4918
Rep 115,980
Mike |
07-24-2009, 08:00 AM | #4 | |
654
Rep 10,587
nice.........
07-24-2009, 08:29 AM | #5 |
11
Rep 354
Without times this post is useless... Looking at the speedo at the end of your run is hardly an accurate assessment :-\ meh
10 Porsche 911 C2S - Cream White / Natural Brown
09 335i E92 LeMans blue M-sport 6MT SOLD: 08 335i E90, 07 335i E92 AW/CR, 93 RX-7 464 rwhp |
07-24-2009, 10:40 AM | #6 |
Rep 3
Mike (or anyone willing to chime in..),
I apologize if this has been answered before. I have an '08 335 with JB+ and solenoid bypass. Can you give me an idea of the type of conditions (temp, humidity, etc) when the JB+ will cut boost. My car feels great sometimes and in other cases, it feels "stock-like" (ie. warm, humid days). Thanx |
07-24-2009, 10:49 AM | #7 | |
60
Rep 2,014
07-24-2009, 11:29 AM | #9 | |
4918
Rep 115,980
Actually I've been poking at BMS to release more aggressive JB+ mapping for those that want it. Maybe when 1.4 is finalized they can get to that. Mike |
07-24-2009, 11:36 AM | #10 |
Seasoned Lurker
Rep 160
Doesn't the JB+ fool the ECU into thinking its at a higher altitude anyway? If so, when you're 6000' and have a JB+ I would think its having trouble squeezing anymore power out of the engine due to oxygen deficiency.
07-24-2009, 11:43 AM | #11 |
80
Rep 761
Man, this sounds like a problem waiting to happen.
335i coupe Montego Blue Dinan stage 3 tune, Advan RS wheels 350whp/365wtq
1994 Brooklands Green Acura NSX Comptech Supercharged 390whp/300wtq |
07-24-2009, 11:47 AM | #12 | |
4918
Rep 115,980
Mike |
07-24-2009, 08:25 PM | #14 |
Rep 19
I am in northern Nevada. The track is at 4k feet but I've seen DA's as high as 8k here in the summer. I think I'd have to agree the heat was the biggest problem. When I left the track I stabbed it at about 80 and it pulled great. This was without having been WOT up to that point so that would be the difference.
RambleJ: The temp was around 90 for the first run. Forgot to mention, this was a night race, started about 7pm. So the conditions only got better as the night went on, not worse. I know not having full slips doesn't help, but the MPH should have gone up if I was making more power. Plus, almost all my runs were against my buddies Camaro and the outcome never changed. I'd jump him off the line, and then he'd pull me the rest of the way. We never finished more than a half car apart. |
07-24-2009, 10:57 PM | #15 | |
654
Rep 10,587
07-25-2009, 10:37 AM | #16 | |
Rep 182
Drives: 2008 335i coupe, montego blue,
Garage List 2008 e92 335i coupe [0.00]
2008 335i coupe [0.00] 2006 325i [0.00] 2006 325i [0.00] 2006 325i [0.00] 2006 325i [0.00] 2006 325i [0.00] 2006 325i [0.00] 2006 325i [0.00] |
I really would like to get a JB+ but I live at 5000' elevation. I know my turbos are already working "overtime" at this elevation. Would a JB+ not be a good idea? Or, would something like a JB3 or Procede be better and would they actually make a significant difference in power at this altitude? |
07-25-2009, 12:09 PM | #17 | |
4918
Rep 115,980
Mike |
