Bad Fuel pump again? Did a BT scan and found this...
07-23-2009, 09:51 PM | #1 |
16
Rep 226
These past few days, I've been getting long cranks and rough idle startups when the car is cold. A couple times, the Engine Malfunction light came on and SES light. I got my BT tool and it found this:
29CF: 29CF Misfirings, cylinder 3 Error will cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold Event 1Odometer 59504kms 36974miles Engine temperature 33.75 °C load value for misfire detection 55.47 % Engine speed 640.00 rpm Lambda integrator group 1 -17.97 % -------------------------------------------------------------------------------- 29CE: 29CE Misfirings, cylinder 2 Error will cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold Event 1Odometer 59504kms 36974miles Engine temperature 33.75 °C load value for misfire detection 55.47 % Engine speed 640.00 rpm Lambda integrator group 1 -17.97 % -------------------------------------------------------------------------------- 29D0: 29D0 Misfirings, cylinder 4 Error will cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold Event 1Odometer 59504kms 36974miles Engine temperature 33.75 °C load value for misfire detection 55.47 % Engine speed 640.00 rpm Lambda integrator group 2 -16.41 % -------------------------------------------------------------------------------- 29F2: 29F2 Fuel high pressure system, fuel pressure Error will cause a warning light Error is not currently present Test conditions have been completed Timeout Event 1Odometer 59712kms 37103miles rail pressure 51,623.67 hPa Engine speed 1,280.00 rpm PWM-Signal of mass control valve 42.19 % injected mass of fuel 9.00 l/h Event 2Odometer 59768kms 37138miles rail pressure 5,434.07 hPa Engine speed 832.00 rpm PWM-Signal of mass control valve 42.97 % injected mass of fuel 5.00 l/h Event 3Odometer 59856kms 37192miles rail pressure 62,491.81 hPa Engine speed 2,912.00 rpm PWM-Signal of mass control valve 53.91 % injected mass of fuel 8.00 l/h -------------------------------------------------------------------------------- 2FBF: 2FBF Fuel pressure at injection release Error will not cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption Event 1Odometer 59768kms 37138miles rail pressure 5,434.07 hPa PWM-Signal of mass control valve 48.05 % voltage Kl. 87 11.07 V fuel pressure before mass control valve 5,306.72 hPa Event 2Odometer 59768kms 37138miles rail pressure 5,434.07 hPa PWM-Signal of mass control valve 47.66 % voltage Kl. 87 11.07 V fuel pressure before mass control valve 5,306.72 hPa Event 3Odometer 59856kms 37192miles rail pressure 5,434.07 hPa PWM-Signal of mass control valve 48.44 % voltage Kl. 87 10.97 V fuel pressure before mass control valve 5,306.72 hPa -------------------------------------------------------------------------------- 29DC: 29DC Cylinder injection switch-off Error will cause a warning light Error is not currently present Test conditions have not been completed Short circuit or signal interruption Event 1Odometer 59808kms 37162miles Engine temperature 80.25 °C air mass calculated 276.72 mg/stk Engine speed 2,656.00 rpm fuel tank filling level 20.00 l Sounds like a bad fuel pump... This is the second pump I've gotten. Any ideas on what else they need to replace? Spark plugs, coils and injectors? |
07-23-2009, 10:54 PM | #2 |
64
Rep 706
Looks like a fuel pump again for sure. I have read about guys on their 3rd pump, and even cars that have gone back to BMW due to the lemon law for the file pump. Hopefully you do not have too many mods, but take off what your can (tune, dps, etc.) and take it back to the dealer and have them check it out.
07-25-2009, 02:26 AM | #4 |
16
Rep 226
Brought it into the dealer. They are replacing the HPFP, all 6 injectors and updating the software. Getting the car back Monday, so we'll see what happens.
07-26-2009, 08:12 AM | #5 |
1112
Rep 3,262
How long has it been since u replaced the pump last time?
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
07-26-2009, 12:27 PM | #6 |
Rep 85
Seems like mine may be on the way out too; just coming up on 2,400 miles on the car
I had code "2FBF Fuel pressure at injection release" trigger along with the SES light, and have had occassional long cranks. |
07-27-2009, 05:59 PM | #7 |
73
Rep 978
Ace, (or anyone else)
I assume the 3 codes regarding the misfires led them to replacing the injectors? Do injectors go bad directly as a result of the pump, or are they unrelated and just a coincidence in this case? I had the codes 29DC, 29F2 and 2FBF which are all pump related I believe, but not any misfires, and they've decided to replace the pump only. |
07-27-2009, 09:06 PM | #8 |
16
Rep 226
Got the car back today. They ended up replacing all 6 injectors and the HPFP. They also performed a software update to 2.34.2.
Mods - JB3 1.3, BMS DCI, RR 2nd Cat Delete, Bastuck Exhaust, Koni FSDs, and H&R Sways. On the report, it said misfire faults: 29CE, 29CF, 29D0, and 29DC. Faults 29F2, 2FBF stored for High Pressure Fuel system. Maybe the misfires indicate the injectors are bad and the 29F2, 2FBF are HPFP? |
07-28-2009, 05:47 PM | #10 |
27
Rep 631
07-28-2009, 05:52 PM | #11 |
73
Rep 978
LOL! Are you serious? You're going to print out this thread and go and show them as proof they should not deny you warranty work?
07-28-2009, 06:11 PM | #12 |
16
Rep 226
07-28-2009, 06:12 PM | #13 |
16
Rep 226
07-29-2009, 03:53 AM | #15 |
16
Rep 226
07-29-2009, 04:37 AM | #16 |
77
Rep 1,232
ACE, did you get the software update while they replaced the pump ?
Mine is sitting at the shop for the HPFP also, and wondering have they updated my software... |
07-29-2009, 12:14 PM | #17 | |
16
Rep 226
Yeah, they updated my car to 2.34.2. Car feels much better. No more turbo lag and a lot more responsive below 3000 rpms. And this is before a tune. I wonder what it will feel like with the JB3 back on. I think I had 29.2 before. |
