TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Air filter question
      07-17-2009, 10:12 AM   #1
I335
I335's Avatar
123
Drives: '08 335i Coupe
Air filter question
Is it OK to clean a stock air filter with a shop vac or an air compressor? Do people not do this because it might just loosen up the dirt and let it into your engine?
      07-17-2009, 10:50 AM   #2
HighVoltage
HighVoltage's Avatar
32
Drives: 07 E90 335i
Youre not going to get it as clean as a new filter, which means you are restricting the flow. The other problem is you may not be able to see a break in the old filter medium that may already allow fine particles through that didnt when new.
If you are going to do it though, I would use compressed air and blow in the opposite direction of the flow through the filter as when it is in the intake tract. That way you arent trying to push any (old) debris through the filter. You are also going to be able to produce more pressure this way versus a vacuum (~14psi). I would start off with 20-25psi and work my way up until I thought it was clean.
The only reason I would do this is if I absolutely had no other choice.
Not only will it kill you it will hurt the whole time while you're dying.
http://www.stevesnovasite.com/
http://www.jalopyjournal.com/forum/
http://www.garagejournal.com/
      07-17-2009, 11:22 AM   #3
I335
I335's Avatar
123
Thanks for the info HighVoltage - makes good sense. I was thinking of doing this just once in a while between filter changes just to keep it flowing as much as possible and wanted to make sure there are no "cardinal rules" against it. Thanks again!
      07-17-2009, 11:27 AM   #4
200Duece
200Duece's Avatar
45
Drives: '73 2002,'18 X5 35d,'17 328d T
its a paper filter and you will probably damage it by blowing any kind of compressed air through it. Or atleast air at a psi that will "clean" the filter. I would just consider tapping the filter to shake free any loose dust or debris, upside down ofcourse, just like you would blow air through it.
And what's a new filter 20 bucks. If it's a cost thing maybe look into a aftermarket drop in that is capable of being cleaned
1988 E28 535is Euro Conversion --- sold
2009 E90 335 6MT --- sold
2003 E39 540iT Msport --- sold
      07-17-2009, 12:46 PM   #5
I335
I335's Avatar
123
Another good point - thanks. It's not a cost thing at all, more of an OCD thing really...
      07-17-2009, 12:52 PM   #6
HighVoltage
32
Drives: 07 E90 335i
@ 20-25psi? I seriously doubt it. Greater than 50psi, probably...
      07-17-2009, 01:58 PM   #7
shifterboy45
shifterboy45's Avatar
23
Drives: 2009 335i Coupe
all the methods work --
i used everyone of them -- compressed air -- shake-tap and outright replacement .. guess it depends on personal OCD traits
i go for the replacement -- unless its a lifetime filter then it gets washed and oiled ..
      07-17-2009, 02:03 PM   #8
I335
I335's Avatar
123
Just did it. It really wasn't that dirty but I used a vac and the compressor. 50psi was no problem but I wouldn't go higher than that. I clearly saw some fine dust blow out of it with the compressor and I also cleaned up inside the air box a bit. There was quite a bit of sand and some small bits of leaves in there. I'm over my OCD now - at least for today...
Thanks again guys.
