ECU cover
07-16-2009, 09:06 PM | #1 |
528
Rep 2,822
Drives: X5M F85
ECU cover
I installed the procede but i could not get the ECU cover completly flush and locked down. Do i risk frying the ECU or Procede due to water damage?
07-16-2009, 09:48 PM | #2 |
اوليسيس
196
Rep 4,678
i think you answered your own question.
and you are the only one that hasnt gotten that lid locked correctly. Someone i know left it cracked open and it cost upwards of $2K to replace every corroded pin that was in that ECU.
07-16-2009, 10:06 PM | #3 | |
Rep 56
Take the lid off and spend a few minutes understanding how it goes on, where it latches. Before you try to re-lid, gently arrange the wires of the various harnesses so that they fit without pressure at about the height of top of the lid with no pressure applied. I found the PROcede and its harness somewhat more difficult to cram into the ECU box than that of various JuiceBoxes, but with patience either will fit just fine. Hope this helps. |
07-17-2009, 07:54 AM | #4 | |
528
Rep 2,822
Drives: X5M F85
Will do, when i get home from work tonight. What happened was i installed the PROcede weds and the cover went on fine, no problem. Then yesterday i threaded the USB through the firewall and when i was done it was getting dark so i did my best to close the lid figuring i would open her back up and close it after work today. I was just wondering if it rained tonight if i would be fk'd |
07-17-2009, 11:48 AM | #5 | |
125
Rep 3,004
07-17-2009, 11:54 AM | #6 |
164
Rep 2,875
^+1, make surer the ECU lid's locks are in the 'unlock' position. Then try wiggle the lid on and close it shut..............
GL
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
06-07-2012, 11:58 AM | #10 | |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
You can either buy the whole cover or the individual locks. Not sure about the lock in the back, though - they don't have a picture/number for it.
The i8 needs a V8 amirite?
06-07-2012, 02:58 PM | #11 | |
545
Rep 7,705
06-07-2012, 03:06 PM | #12 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
I should point out, that is for an 07 E90 335i, you'll want to go to the homepage of realoem.com and start over with your exact car. But you can use my link as a reference to get to that part.
