The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Universal dyno - wheel spin
      07-16-2009, 09:18 AM   #1
Dunwitu
Drives: 2011 335xi SE
I'm still trying to get to the bottom of my tune. Got a Dinan Stg 2 flash in my '08 w/step. There is some improvement, but nothing down low. Had it dyno'd, numbers were low, took it back to dealer, they checked for fault codes....nothing, so here I am. Before I resign to the fact that this is all I get, I want to solve one final question.
My car is a stock e90 sedan w/sport package(stock potenza's). I have zero slippage regardless of which traction or transmission mode I'm in (when accelerating in a straight line).
Should I have any wheel spin?
Not that I really want wheel spin, I just want maximum power from my tune. Looking for comments from other sedan owners with auto and Dinan S2.
Thanks
      07-16-2009, 09:32 AM   #2
stealth-twntrbo
stealth-twntrbo's Avatar
139
Drives: 2020 740xi
What kind of numbers did it put down, and the Dinan doesnt put down that much power alone with out supporting mods. I dont think with just a Dinan your going to get much wheel spin.
      07-16-2009, 09:48 AM   #3
Salco3
Salco3's Avatar
Drives: E90 325i & E39 M5
What type of Dyno are you using? keep in mind that without proper air being pushed into the intake you will never be able to get real power generated.
      07-16-2009, 10:21 AM   #4
edo
edo's Avatar
Mexico
53
Drives: E92 335i
What do you mean by saying wheel spin? Which gear? From a dig or roll?
I don't know about AT, but I had wheel spin in second gear even when my car (MT) was stock. And my rear tyres are 275/30 R19.
Mods: RB turbos, JB4, BMS DCI, Scoops, Forge DVs, ar design catless DPs, Milltek exhaust system, Helix FMIC, Quaife LSD, VK MotorWerks OC Kit, Bilstein B16 PSS10
      07-16-2009, 11:20 AM   #5
dlbrooks18
dlbrooks18's Avatar
161
Drives: e90 335i
I got Dinan stage 2 and '08 step too.. are you turning DTC/DSC completely off?
      07-16-2009, 11:25 AM   #6
vegasspeed
vegasspeed's Avatar
80
Drives: 335i 6MT coupe Montego Blue
wheel spin shouldn't be a factor. You are getting too worked up over the dyno numbers honestly. Each dyno will be different. If you wanted big numbers than you should have gone a different route. As long as your car fells good when you drive it than don't get so worked up in this. Your dyno will make a huge difference since Mustang dynos, dynodynamics dynos and dynojets all do things differently and give quite different results.
335i coupe Montego Blue Dinan stage 3 tune, Advan RS wheels 350whp/365wtq
1994 Brooklands Green Acura NSX Comptech Supercharged 390whp/300wtq
      07-16-2009, 12:37 PM   #7
Dunwitu
That's the reason for the thread. I'm not hung up on the numbers themselves, only how much power my car is making (although the mustang before me laid down 612 at the wheels compared to my 276).
I've tried every scenario, traction on, dtc pressed once, dtc completely off, auto, ds mode, m1.
A friend who had an older Vishnu in his 07 had no problems lighting them up (we can't compare cars because he already upgraded to a M3).
I'm not looking to spin the tires (i have a 420hp mustang for that), I only want to know how the Dinan is supposed to perform. It pulls hard when it's going, but overall not as much as I expected, especially off the line.
Again, I'm only asking about cars with step
Thanks
      07-16-2009, 05:37 PM   #8
SuPaSkillz
SuPaSkillz's Avatar
Drives: 2008 e90 335i /2007 E63 M6
Dinan doesnt make there products with big power in mind. Get a jb+ and leave it on Default/lower setting... prob fixed.
