Help Procede
07-14-2009, 03:59 AM | #1 |
Rep 153
Help Procede
Hi guys,
Please could you tell me how I read the DME codes? I tried 20 times and I can not, I have installed Procede v3 revII CanBus. When i push the throttle to the floor with the procede reader on, I can see the engine simbol but nothing else. What is the procedure? Shiv I already know that you are writting the "documentation" but could you help me. Thank you |
07-14-2009, 06:31 AM | #2 |
30
Rep 1,748
http://www.vishnutuningforum.com/for...read.php?t=412
try following those directions... Debug word 7 shows trouble codes... That's also what Shiv showed me when he installed mine... Otherwise you might want to invest in a BT tool... which I think i'm going to get myself... even though the procede can clear codes...
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi) 2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune |
07-14-2009, 07:19 AM | #3 |
Team Zissou
3065
Rep 10,197
07-14-2009, 07:27 AM | #4 |
30
Rep 1,748
awesome... Didn't know about debug word 8, thanks for the additional info jpsimon
07-14-2009, 09:16 AM | #5 |
219
Rep 8,375
Drives: Just a car
you need laptop to read the codes if you have any.....codes don't show up in your dash!
07-14-2009, 02:24 PM | #6 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
If you download the new user software (see link in my sig), there is now a datalog parameter called 'DME Diagnostic Codes'. No need to look at any debug channels. And no need to do any set-up. All pre-configured for easy use.
Shiv |
07-14-2009, 03:52 PM | #7 | |
Rep 153
Hi Shiv, I dowload the new user sw and there is now a "DME Diagnostic Code", but nothing happens! Only I see the engine symbol on display. In my lapto nothing. When I set "start data log" and after that "End data log" and I open the file with the channel enabled (DME Diagnostic), nothing. All that with the throttle pushed 1 second before. What have I do? |
07-14-2009, 03:56 PM | #8 | |
1737
Rep 17,960
Drives: A Lot
When the engine symbol on your display illuminates, your codes (if present) will be displayed under DME Diagnostic Codes. If there are no numbers flashing, then you have no codes. Shiv |
07-14-2009, 04:26 PM | #9 | |
Rep 153
I am sure it says "connected to procede" at the bottom, and when the engine symbol iluminates, do I look in the right window in the DME Diagnostic Codes channel? I donīt see changes in this channel, although in other channel I see readings of throttle for example. Must I have some codes when I update the firmware? Even when I did it, I didnīt see nothing. Can I force some code to check that all works correctly? Shiv today updated the firmware to 125, I noticed in valet mode less energy, is it possible? Now in valet mode is there less gas consumption than stock?, I remember that you told me. Today I am to 800metres, but yesterday with firmware 123 I was to 0 metres ( I could see the channel "wastegate DC limit= debug word 4" to 50-51 in the sea level but in Madrid to 800m the channel is on 45. Is it the reason? Shiv other thing: what is the channel to read the real opening of intake air valve. Thank you |
07-14-2009, 04:34 PM | #10 | |||||
1737
Rep 17,960
Drives: A Lot
Shiv |
07-14-2009, 04:36 PM | #11 |
///M Specialist South Shore BMW
772
Rep 7,108
My car will only do the code reading when all doors on the car are closed. If the doors arent closed it wont even show the engine malfunction symbol.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
07-14-2009, 04:54 PM | #12 | |
Rep 153
Shiv when I installed 2-19 map or older, I remember that in valet mode my car consumed less gas than stock, perhaps I am wrong but I liked very much and I remember to hear something regarding this issue. Then is normal "Wastegate Dc limit out=debug word 4"=51-52 to 0 metres in the sea and 45 to 800metres?? Excuse me but I have many question and I donīt want to disturb you, I have question about clear codes, when i clear the codes, I reset the adaptation of DME (is it the same that I see in the "user pocede" called reset ECU?) Thank a lot Shiv. |
07-14-2009, 05:01 PM | #13 | |||
1737
Rep 17,960
Drives: A Lot
Shiv |
07-14-2009, 05:06 PM | #14 |
30
Rep 1,748
Sweet, I tried it out and I like the new addition, keep up the good work shiv
07-14-2009, 05:15 PM | #15 | |
Rep 153
Shiv I notice perform cyclical changes with the engine without Procede, I thing that the DME sometimes automatically resets. I notice better response when that happens. I thought that Procede reset the DME when pressed the trottle, at least before I noticed the reset with older map, I would like to have this feature please.
