Bavarian Autosport Tri-Flo Performance Mufflers - Touring Sound?
07-10-2009, 10:27 AM | #1 |
BMW CCA Member #420698
17
Rep 720
Anyone have this set up?
Sound? Drone? Reduced backpressure gives your BMW an instant horsepower boost! The stock BMW muffler has a vacuum-activated butterfly valve on the driver's side muffler. This valve is closed under most conditions, diverting all exhaust gases to the passenger's side tailpipe. Under certain conditions (e.g. high throttle/low vacuum), the butterfly valve opens so two mufflers can be used. The Touring version of our Tri Flo exhaust duplicates the actuator and butterfly valve, so it operates in the same way as the stock exhaust. However, the muli-chambered design of our Tri Flo allows exhaust gasses to flow more freely. The result is a slight increase in horsepower and a more resonant sound when the butterfly valve is closed, but a bigger boost in power and a throaty growl when you hit the throttle hard. (For an even more aggressive sound, consider the Sport version of this exhaust which eliminates the actuator and valve.) Stainless steel construction. Limited lifetime warranty. Simple Cut/Clamp installation. Includes left and right mufflers. Part Number Description Price Qty. BB335E90T Bavarian Autosport Tri-Flo Performance Mufflers - Touring Sound $1324 http://www.bavauto.com/lview.asp?img.../bb335e90t.jpg |
07-10-2009, 01:11 PM | #2 |
51
Rep 2,361
Looks exactly like the mufflers Eisenhaus tried to pass off as authentic Eisenmann back in the day.
