KW V2 Installed... CLunking Noise??? PLEASE HELP
08-25-2006, 11:33 PM | #1 |
I found Jesus...He was Hiding behiind my Sofa
69
Rep 957
I need you input guys. As the title says, I installed (at a local wheel & tire shop) my brand new KW V2 coilover kit.
My problem is that ever since I left the shop, I have a continous clunking noise in the rear whenever I go over a bump. Even the slighest road inperfection causes the noise, as if something was loose. Shop noticed the same thing upon test driving and said it needed a different stop or perhaps it was the wrong kit and that everything was tight. I called KW tech support and they said that it was the correct kit and needed nothing else except the use of some OEM parts (which appeared to be used by the shop). I will be going back to the shop to have them look over their work once again, but would like to point them in the right direction as they are sure it is not their fault (i.e."correct torque, etc"). Thanks to everyone in advance for your comments, suggestion, & advice
08-25-2006, 11:45 PM | #3 | |
69
Rep 957
Thanks for the reply. This noise is def. not normal. It sounds like the rear is going to come off, but shop swears it's tight and proper.
08-26-2006, 12:03 AM | #5 | |
69
Rep 957
I might have to, but have to give them another chance, especially since I paid them for the work. They've actually done work for me in the past and for other local E46 members. They do good work, that's why I was wondering if anyone knew what it might be before going back. Thanks again!
08-26-2006, 12:23 AM | #6 |
195
Rep 4,079
Drives: F30 328i
Did they mount the springs in the rear upright??The springs are desinged to go on only one way and u need to make sure your rears look like this with tthe stock black mount REMOVED! notice how the adjuster is on the top in the car practically!
08-26-2006, 06:25 AM | #7 | |
69
Rep 957
Thanks million ADHD. I've spent all night looking for a clear pic like that. That might be the problem right there since I think they used the stock part.
08-26-2006, 10:56 AM | #8 | |
195
Rep 4,079
Drives: F30 328i
08-27-2006, 12:37 AM | #9 | |
69
Rep 957
BTW, di dyou have to roll your fenders or just adjust the damper in the rears, cuz I'm rubbing like crazy now, but no clunky clunk clunk. lol
