Riss Racing Catted DP Question
07-08-2009, 08:34 PM | #1 |
47
Rep 726
I just finally installed the RR catted DP's yesterday and I have to say that the car feels very different. It seems like more torque is available on demand, and the exhaust note is that much sweeter.
My question, though, relates to something that happened today. I was driving the car around town and all of a sudden the Service Engine Soon light came on, and it showed me a diagram of what appeared to be an engine with a line running diagonally through it. Has anyone else had this problem? Any suggested fixes?
2007 E92 335i--SG, Fully loaded, minus the dead weight..err..iDrive and Active Steering. |
07-08-2009, 08:51 PM | #3 |
47
Rep 726
hmm, I thought that may be the case..
Would it be normal that it took it a while for the Service Engine Soon light to come on?
07-08-2009, 09:09 PM | #4 |
130
Rep 5,040
sometimes it takes a while for the sensors to trigger a fault, and other times its instant from what I hear. Thats too bad that the catted downpipes trigger a CEL though, perhaps you can get in touch with someone at RR?
07-08-2009, 09:29 PM | #5 |
47
Rep 726
The only number they list on their website is for sales, and it is also the same number as their fax line so when I called I eventually got that annoying, screeching fax tone.
I'm going to email them tomorrow, but I'm also headed out of town so I guess I'll just have to wait until I get back to resolve the issue. But, like you said, its too bad that the catted downpipes still throw codes. I was assured they wouldn't.
07-08-2009, 09:53 PM | #6 |
47
Rep 726
As well, when I start the car, out from the exhaust comes this horrible noise which I can only describe as a mix between "burbling", "gasping", and "choking".
Don't know if that helps at all to diagnose the problem, but I thought I'd pass it along anyway.
07-08-2009, 10:00 PM | #8 |
82
Rep 1,389
Dude, it's well known that most aftermarket DP's, be that catted or catless, will trigger an O2 code.
The only solution is to get an O2 Simulator and install it into your ECU. I have the BMS one here: http://www.burgertuning.com/dpfix.html It works fine. I have the same downpipes and the CEL is normal. Your biggest challenge now is getting the actual code cleared. If you don't have a Bavarian Technik Scanner, you are SOL. If you have to take your car in for service...even just an oil change, they're gonna know that you've modded the car.
"SYONRA" is for sale! http://www.e90post.com/forums/showthread.php?t=366678 BSM '09 e92 335i | Performance: JB3, RR Catted DP's, INJEN DCI, Britalman Exhst, AA FMIC, FORGE DVs | Suspension: ST-V1 Coils, Hotchkis Chassis Brace & F/R Sways | Wheels: Bremmer Kraft BR03s, Brake Performance Rotors, Cool Carbon Pads, ECS Lines | Exterior: OEM Aero Lip/Rear, ****** CF Trunk Lid, BLUX5 Angels, M-Force M3 Sides | Interior: Passport 9500ci, Black Trim, M3 Wheel
07-08-2009, 11:19 PM | #9 |
47
Rep 726
I'm not too sure about the commonality of these Bavarian Technik Scanners, but my mechanic works exclusively with BMWs and Benzs. Would it be safe to assume that he probably has one, or not?
Before people get needlessly defensive, I just want to state that the following question is being asked with all sincerity: What is the point of making a catted downpipe if it throws codes just the same as the catless version?
07-08-2009, 11:30 PM | #10 |
164
Rep 2,875
Where in Oregon are you? Portland?
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
07-08-2009, 11:33 PM | #11 |
47
Rep 726
I live in Eugene, but I head up to Portland very often because my brother is attending the art institute.
07-09-2009, 12:25 AM | #12 | |
82
Rep 1,389
Your independent mechanic should be able to clear the regular codes, but I can't say for sure about the shadow codes, which are the hidden codes that a Bav Tech tool will catch and erase.
07-09-2009, 02:23 AM | #13 | |
47
Rep 726
What I was asking is, if the Riss Racing downpipes which have cats cause error codes, and the Riss Racing downpipes which don't have cats cause error codes, what is the point and/or advantage of producing downpipes with cats if, in the end, both are going to cause error codes?
07-09-2009, 07:16 AM | #14 | |
82
Rep 1,389
Bottom line, the point in buying aftermarket catted pipes is you get more exhaust flow over stock...at the expense of potentially throwing O2 codes...as you have discovered.
07-09-2009, 11:46 AM | #15 |
375
Rep 17,017
You can just pick up an O2 sim to get rid of the codes but your indy mechanic should be able to clear them. If not, you can head to AutoZone or Pep Boys and borrow their code reader to clear them.
07-09-2009, 11:59 AM | #16 | |
One cam is enough
130
Rep 6,801
Why get catted when they throw codes anyway? The answer is: I dunno. I personally wouldn't want a set unless they were guaranteed not to throw a code. Otherwise, might as well go catless.... |
07-09-2009, 12:03 PM | #17 | |
82
Rep 1,389
I have had a free-flow setup and the sound and smell were too much. So I went back to catted, but with aftermarket Riss pipes. There is still a performance increase, but it's not as much...and it's not as loud...and not as stinky.
07-09-2009, 12:08 PM | #18 | |
One cam is enough
130
Rep 6,801
Funny I never thought about it the way you're putting it. The catted, in a system with no more cats downstream, is sort of an "intermediate" option as far as performance , loudness, and stinkiness goes.... |
07-09-2009, 12:11 PM | #19 |
Chief Executive
300
Rep 2,886
Drives: 2008 335xi 6spd Coupe
07-09-2009, 12:12 PM | #20 | |
Chief Executive
300
Rep 2,886
dR |
07-09-2009, 12:40 PM | #22 | |
82
Rep 1,389
