Cylinder 2 & 3 misfire.......
07-08-2009, 02:42 PM | #1 |
164
Rep 2,875
I've been getting P0302 and P0303 and P0300 codes ever since I loaded the 7-03 maps...........Does this have to do with the beta maps you think?
Or is it something else, like faulty coils? FWIW, I'm running stage 3. TIA
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
07-08-2009, 03:04 PM | #2 |
only in it for the torque - awuleth'umshini wami
50
Rep 425
Drives: sapphire black 335i
Look at your signature mod # 3
07-08-2009, 03:16 PM | #3 |
164
Rep 2,875
CL DPs? I've had them for about a year, with O2 SIM and no problems until now.........R U serious?
Anyone else? Please chime in........... TIA
07-08-2009, 04:00 PM | #6 |
164
Rep 2,875
I just changed my plugs about 4-5 months ago, all six of them..........Please don't tell me I have to change them AGAIN!!
07-08-2009, 04:25 PM | #7 |
hi
129
Rep 1,140
spark plug or injectors my friend same problem here.
2022 M Sport G05
Jb4, CTS catless dp, M performance exhaust, bms intake, IND goodies, Maxton kit |
07-08-2009, 04:33 PM | #8 |
164
Rep 2,875
Are there better plugs available? I just changed all 6 with OEM Bosch plugs..........
How often do we have to change the plugs on a tuned car? I thought once a year would be sufficient........... TIA
07-08-2009, 05:21 PM | #9 |
20
Rep 325
i would put my money on the plugs...personally i pulled mine off before i bought new plugs. even with a tune once a year seems a bit much unless you're putting 20,000+/year
07-08-2009, 05:36 PM | #10 |
164
Rep 2,875
yeah, I thought once a year is a bit much too!! So if I change the plugs again, and that happens to be the issue, then I have changed plugs twice in a year!! WAY TOO MUCH, wouldn't you say?
That's why I thought it might have been something else, since my plugs are fairly new.......If you know what I mean. TIA
07-08-2009, 09:35 PM | #11 |
Rep 183
Witch plugs do you guys sugest?? OEMs?
I've put 36k miles on my car, 34k of them tuned all the way back from v1.45 days! I know I need to change them soon... |
07-09-2009, 02:06 AM | #12 |
161
Rep 7,377
Only OEM are available now. I have asked HKS about their performance plugs but havent got an answer yet .
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
07-09-2009, 05:16 AM | #14 |
307
Rep 5,175
Before you blow the money on plugs. Swap coil 1 with coil 2, then swap coil 4 with coil 3. If the misfires follow the swap to 1 and 4, then it is bad coil packs.
07-09-2009, 07:51 AM | #15 |
153
Rep 5,780
I concur. I would add that if the misfires continue at the same location, move the plugs in the same manner. If it persists at the same location, that would most likely be a fuel injector.
07-09-2009, 08:29 AM | #16 |
232
Rep 1,481
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Garage List 2004 Honda Hornet [0.00]
2003 Chevrolet 2500 ... [0.00] 2011 BMW S1000RR [0.00] 2011 BMW E92 M3 [0.00] 2012 BMW E92 M3 [0.00] |
Also what I did for my misfires!
07-09-2009, 01:26 PM | #20 |
164
Rep 2,875
Ok, my next question is probably a stupid one.........
Is cylinder 1 towards the front of the engine or towards the back........LOL. That way I know which way to count and won't get the wrong cylinder....... TIA
07-09-2009, 03:55 PM | #21 |
50
Rep 425
Treat the cause not the symptom
Mod number #3
07-09-2009, 05:47 PM | #22 |
164
Rep 2,875
Do you think it could also be cause by my CL DPs? As someone had suggested? I figure, if that was the issue, I would have encountered this a long time ago. As I've had the CL DPs for about a year now......
TIA
