The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > front turbo leaking oil.....advice ? ok to drive ?
      07-06-2009, 12:01 PM   #1
inthemiddle
37
Drives: 335i
So... i was down there fixing a leak with the DP gasket and noticed that my front turbo was leaking oil...
I know a little oil leaked goes a long way in terms of spreading out, looking messy..etc... There really wasn't too much down there... but certainly at least a tablespoon or two has leaked out...
The most covered part of the turbo itself is that little clamp looking thing just behind what looks like the oil ports...etc.. I have no idea how these are built inside... seals..etc... but that clamp has a black coating on it now where the oil has cooked on, and a slightly damp coat of oil/grime over it... then below there... spreading out a few inches in each direction, everything was a bit dirty...
Any ideas as to if i should expect any catastrophic failures based on it leaking there, or should i be ok if i just keep an eye on it.. monitor the oil...etc..
still pulls plenty strong with NO excessive turbo noise..etc... kinda wondering might it be a leak somehow on one of the fittings for the oil running through it...or is the turbo itself somehow two pieces held together with that clamp thing... leaking out there... etc.. I don't know... never had one leak oil on the outside before... (owned lots of turbo cars in the past)
advice ?
      07-06-2009, 12:11 PM   #2
hotrod2448
grand poobah
hotrod2448's Avatar
254
Drives: F80 M3, F10 535i
2011 335d  [0.00]
I'd get it fixed ASAP. Not knowing how long it's been leaking you don't know if it's just a little bit weeping out of or it's just started and is a severe leak. Either way scorching hot exhaust manifolds and oil are not a good combo.
I'm assuming you are talking about the V-band clamp that holds the cartridge onto the hot side.
      07-06-2009, 12:33 PM   #3
inthemiddle
37
Drives: 335i
yea... i guess that's what it is... ..
and yea... that exactly.. that clamp is where it looks like is coming from... or one of the oil line connections right next to it...
odds are that it's coming from inside ?? leaking past the clamp ??
The only part of the turbo the oil is hitting is the clamp itself... then looks like maybe a small drip or mist/spray that seems to fall/be blown down and back...
good point about that whole fire thing though....
although the manifold and the rest of the turbo housing is clean... even the rest of the hot side of the housing...
i cleaned a lot of it up... as best i could with a rag... driven it just a little bit since then.. will crawl under there and take a look again...see how bad it looks... (really don't want to deal with swapping DPs, intercooler..etc.. though.. AND STILL have to deal with the dealer on top of all of that)
anyone have any idea what part of it might have issues... or is it likely just a turbo replacement in order...
if so... what's it like to change the front turbo ??? (i've done the DP.. not fun.. but not hard by any means... seems like it might not be too bad to get the turbo/manifold off ??? but now sure how i'd get it out of there and a new one in.. ... seems like there is some stuff in the way...
