Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > jb3 Problems anyone?
      07-06-2009, 01:36 AM   #1
bmw3355
14
Drives: bmw
has anybody encoutered any jb3 related problems i am worried about my car after 60,000 miles what you guys think? has anyone experienced problems?
      07-06-2009, 01:39 AM   #2
JB335
33
Drives: 335is
2011 BMW 335IS  [7.60]
Have had my Jb3 for 15,000 miles. So far so good.
      07-06-2009, 01:43 AM   #3
bmw3355
14
Drives: bmw
cool your not worried about long term? and do you have an oil cooler or intercooler? is it bad to have the jb3 without those mods?
      07-06-2009, 01:49 AM   #4
JB335
33
Drives: 335is
I have the stock sport oil cooler. I have a Helix intercooler, though its not installed yet.
Just run the appropriate map for the mods and gas you have. Any tune is going to decrease the life of the motor. Dinan, jb, vishnu, etc. When the turbo's are spinning faster and the horsepower is increased by 30% the mechanics of the car will be working harder.
Some people have 50k tuned miles with no problem. 99% of us have not featured any type of engine failure, regardless of the tune. Being a semi new production car, there aren't many, if any, tuned 335i's running around with 100k+ miles.
      07-06-2009, 01:53 AM   #5
bmw3355
14
Drives: bmw
ye for sure its just dinan only boosts 13 psi and they require an oil cooler to provide their warranty at that and when they boost any higher they requier and intercooler as well as an oil cooler i figured there must be a reason for that you know i dont have either i dont think and am a little worried about adding the jb3 what you think
      07-06-2009, 02:02 AM   #6
JB335
33
Drives: 335is
Well the JB3 has different maps. Ranging from 1-9. 1 being 11-13psi and 9 being 15-17 psi. Each map requires certain modifications, just like the Dinan tune. So if you choose the appropriate map for your car and modifications, you are essentially given the same protection as the Dinan tune.
Map 0:
-- Disables JB3, all signals pass through
Map 1:
-- Low boost map, boost levels of 11-13psi depending on mods and weather
-- Self adapts to modifications like intake, downpipes, exhaust, etc
-- 91 octane RM2 or higher required. The higher the octane, the more power.
Map 2:
-- Performance map, boost levels of 12-14psi depending on mods and weather
-- 91 octane RM2 or greater required. The higher the octane, the more power.
Map 3:
-- Identical to map 2 with additional low end response (aka lagfix)
Map 4:
-- Hotter Performance map, boost levels of 13-15psi depending on mods
and weather
-- 93 octane RM2 or greater required. The higher the octane, the more power.
Map 5:
-- Identical to map 4 with additional low end response (aka lagfix)
Map 6:
-- Designed to optimize bolt on performance
-- Richer midrange air/fuel ratios to sustain additional torque
-- May trigger hidden tuner detection codes. Purchase a Bavarian
Technic cable from BMS to scan for and delete any hidden codes before service.
Map 7:
-- Identical to map 6 with additional low end response (aka lagfix)
Map 8:
-- Race map
-- 97 octane RM2 or greater required. The higher the octane, the more power.
-- Modifications like intake, downpipes, and intercooler strongly suggested
-- Lagfix enabled
-- May trigger tuner detection codes
Map 9:
-- More aggressive race map
-- 100 octane RM2 or greater required. The higher the octane, the more power.
-- Intake, downpipes, and intercooler required
-- Lagfix enabled
      07-06-2009, 02:04 AM   #7
persian54
persian54's Avatar
923
Drives: M760/G83M4
jb335, your car looks sexy.
love the white on red.
what do you have to get the 423tq?
hard to believe just jb3...
      07-06-2009, 02:08 AM   #8
JB335
33
Drives: 335is
Thanks persian. I had the JB3, AR catless downpipes, and BMS dual intake.
http://www.e90post.com/forums/showthread.php?t=245785
      07-06-2009, 02:11 AM   #9
persian54
persian54's Avatar
923
Drives: M760/G83M4
aahh DPs ok that makes sense now heh
If i can learn how to put them on and take them off myself (dont want to go to service with them on) I'll get some
how does the dealer treat you?
(sorry dont mean to steal this tread...)
      07-06-2009, 02:14 AM   #10
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
if you are sooo worried just run the low boost map...
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      07-06-2009, 02:15 AM   #11
JB335
33
Drives: 335is
I was in a car accident and the bodyshop took my car to the dealer for it's final diagnostics scan. Even though I requested I get a hold of the car before they send it in, they mistakenly took it anyway.
The dealership had my car with the JB3, Rix gauge, intake, and downpipes. They didnt say a word. They said, it runs great, and they loved the integrated boost gauge.
so, so far I've been lucky. However, now that I have a catless exhaust with the catless downpipes, I think they may not be so lenient. We'll see. :knocks on wood:
      07-06-2009, 02:33 AM   #12
CJ_LO
26
Drives: X5 35I
2014 F15 X5 35I  [0.00]
which jb3 map were you on to get those dyno numbers?
388 / 423
      07-06-2009, 02:35 AM   #13
enrita
enrita's Avatar
Sweden
161
probably map 6/7 ? my numbers are below on map 6.
      07-17-2009, 03:35 PM   #14
iE92Beasst
Youngest 335i Owner + Jb3 map 7 = Me
iE92Beasst's Avatar
Drives: 2007 335i
2007 335i  [0.00]
Could i run map 5 with just the dual intakes?
