RR Downpipes
07-04-2009, 12:25 AM | #1 |
Rep 29
RR Downpipes
Anyone notice considerable change in cabin noise and vibrations after downpipe install. Have stock exhaust, car feels likee its running rough but it's not. Thanks in advance.
-Angelo- |
07-04-2009, 12:34 AM | #2 |
102
Rep 2,760
Did you just install the downpipes? Are you implying the down pipes give you a rough running engine sensation?
I am stock and was thinking about having Sniz install some on my ride, but had a scare a few weeks ago that cost me some $$$ so I was just a tad nervous about touching the car anymore. I am not real superstatious but have had some adventures with the car and thinking maybe I should just leave good enough alone rather than risk any new drama with it.
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
07-04-2009, 12:42 AM | #3 |
Rep 29
Dont get me worng for performance to money ratio this is by far the best mod I have done to my car to date, but I have notcied an increase in cabin noise and slight tremor like vibrations,., kinda like a drone when the car is in idle,., could it be the gaskets not on good??? other than that really happy.,. car is idling great just feels and sounds diffrent,.,.,.
07-04-2009, 04:17 AM | #4 |
Rep 44
I dont have downpipes but im sure that they would change your exhaust note, just makes sense.
If only my car was as exciting as my bike
07-04-2009, 01:32 PM | #5 |
375
Rep 17,017
The downpipes are going to make the car sound louder so that should be expected. I do recommend replacing the factory exhaust to maximize the power gains from the downpipes. Have you allowed the software to adjust to the increased air flow?
07-04-2009, 01:48 PM | #6 |
297
Rep 4,408
Downpipe should not add vibration. They are hitting/rubbing somewhere.
-Critter
07-05-2009, 08:37 AM | #7 |
only in it for the torque - awuleth'umshini wami
50
Rep 425
Drives: sapphire black 335i
I am assuming catless DP?
I Agree with AR: The sound will be louder but there should be no vibration. And I agree with Nick: There will be a "tremor" sensation running through the exhaust due to the increased airflow but it subsides after a few miles or you will get use to it. Cabin noise? I would not describe it as noise or drone...a deep, throaty, raw, nice rumbling sound - yes! When cruising the car should sound stock. When you accellerate a deep growl changing into a howl will be evident in cabin... On my previous 335 I kept the rear mufflers stock but everything else was catless and freeflow. On my current 335 i started at the back with the BMW performance exhaust working forward. Performance WILL increase if you change the stock mufflers and run it with the DPs (whether catless or catted).
07-05-2009, 01:27 PM | #8 |
375
Rep 17,017
07-05-2009, 06:12 PM | #9 | |
297
Rep 4,408
-Critter
