Uninstalled O2 sims and boost gauge, but now car won't start
07-03-2009, 07:02 PM | #1 |
Modaholic
88
Rep 1,705
So, I uninstalled the O2 sims and boost gauge... Stock downpipes are on, but now, I'm getting these codes...
P0123 - Throttle Position Sensor/Switch A Circuit High Input P0222 - Throttle/Petal Position Sensor/Switch B Circuit Low Input P1417 - Port Air Relief Circuit Malfunction The car is trying to turn over, but it won't start... any ideas?
Euro Delivery - April 2007
07-03-2009, 07:04 PM | #2 |
hi
129
Rep 1,140
maybe the ecu connections are loose?
2022 M Sport G05
Jb4, CTS catless dp, M performance exhaust, bms intake, IND goodies, Maxton kit |
07-03-2009, 07:05 PM | #3 |
Modaholic
88
Rep 1,705
Do you know which ECU connections I would have to check for that?
07-03-2009, 07:18 PM | #4 |
654
Rep 10,587
check the large ECU connectors and also triple check the wires you just messed with for the 02 simms, betting you mixed them up.
07-03-2009, 07:20 PM | #5 |
hi
129
Rep 1,140
i've never installed o2 sims but check to see if everything in the ecu is connected right, nothing loose. large and small connector and any other wires you messed with.
2022 M Sport G05
07-04-2009, 12:02 AM | #6 |
Modaholic
88
Rep 1,705
Well, I fixed it, but I don't know what I did to fix it. All I did was take everything apart again, wiggle connections, and then WA-LA! Weird... but I'm glad it's all fixed.
Thanks guys!
