Ticking Sound When Using the JB3 Lagfix Maps? Not Anymore
07-02-2009, 01:07 PM | #1 |
Modder Raider
753
Rep 8,633
Drives: M3
I worked with Terry to come up with a solution to fix the ticking sound that people were having with the wastegates.
Recently people were finding that when using the lagfix maps on the JB3 and other tunes, there would be the wastegate rattle during idle and deceleration. When using the non lagfix maps, the rattling would go away. The non lagfix maps work the same as the stock configuration, but the lag fix maps close the wastegate more at idle and deceleration. This is why the ticking happens because the wastegate is closed so much that it rattles against the seal. I came up with an adjustment that anyone could make for the rear wastegate, but this is only if the ticking is happening with the non lagfix maps or during the stock maps. http://www.e90post.com/forums/showth...6269&highlight The ticking would have nothing to do with the performance or anything of the sort, but it is very irritating. Before, if people were experiencing the rattling, then they would have to resort to the non lagfix maps. Now, there is no issue with both. I just wanted to comment on this to reitterate that these new JB3 maps work because I know that there are a lot of people out there that experience this issue. The map can be found here: http://www.e90post.com/forums/showthread.php?t=277850
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
07-02-2009, 01:16 PM | #2 |
161
Rep 7,377
yep new maps with lagfix are awesome! my rattle is gone !
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
07-02-2009, 01:41 PM | #3 |
only in it for the torque - awuleth'umshini wami
50
Rep 425
Drives: sapphire black 335i
well done Mr.5
Where can i find updated JB3 maps?
07-02-2009, 03:00 PM | #4 |
161
Rep 7,377
n54tech.com maybe??? or check Mike thread about the new beta maps.
07-02-2009, 03:19 PM | #5 |
Modder Raider
753
Rep 8,633
Drives: M3
Or you can check the first post.
07-03-2009, 01:41 PM | #6 |
50
Rep 425
Thanks! Appreciate.
