Lightweight Crank Pulley Release
07-01-2009, 08:43 PM | #1 |
48
Rep 963
We have been working on getting lightweight pulleys made for the 335i for quite some time now. These pulleys are significantly lighter than the stock pulleys, but retain the same dimensions. The reason for this is that we believe the few extra horsepower that comes from under driving the accessories isn't worth the potential problems it could cause. An added bonus of this is that the stock belt will work with the lightweight pulley as well.
We will have dynos up next week. If gains are worthwhile, we will post pricing up and then start taking order. Stock weight = 6.97 lbs Aftermarket weight = 1.97 lbs Materials = T-6061 aluminum Specs = stock diameter Pictures: Last edited by Ryan@Motorwerks; 07-02-2009 at 01:41 PM.. |
07-01-2009, 10:58 PM | #6 | |
Modder Raider
753
Rep 8,633
Drives: M3
It's about fricken time man!!
I'd love to be first on the list. Quote:
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
07-01-2009, 10:59 PM | #7 |
ASR Turbos+LSD+Meth= :D
73
Rep 1,517
Drives: E92 335i
wow i guess the m3 isnt the only one that gets this
2007 335i Coupe Mods: Check the Garage |
07-01-2009, 11:24 PM | #11 |
Just some guy
49
Rep 1,531
my cousin owns NST. theyre big in doing JDM pulleys. i'll have him look at my car and see if the pulley is even worth improving.
2008 BMW 335i/Sedan/Alpine White/Terra/Steptronic/Premium Package/Sports package/Comfort Access/USB/Sirius
07-01-2009, 11:28 PM | #12 |
48
Rep 963
The finished pulley just came in today, so baseline dyno tomorrow and after dyno on moday (or tuesday if monday isn't possible). I can't wait to see what this bad boy will do.
We will find out if its worth doing once the dyno results come out on monday or tuesday! |
07-02-2009, 04:06 AM | #17 |
38
Rep 944
nice more mods inc..
http://www.youtube.com/user/Ferre86
| e93 M-DCT ESS VT2-625 | Akra Slip-on | Challenge Race Catless x-pipe | Challenge front lip | Challenge Diffuser | Carbon front grilles | defi gauges control unit | Macht Schnell gauge panel | E93 M3 trunk Spoiler | IND Carbon Fiber Side Markers | |
07-02-2009, 11:33 AM | #18 | |
48
Rep 963
We simply won't dyno the car again until conditions are close to matching those taken during the baseline. Also, I'm uploading pictures at this moment so they will be up in 2 minutes! |
07-02-2009, 11:34 AM | #19 |
18
Rep 429
I've not bothered to look it up but is the crank "pulley" a pulley by itself or is it integrated with a harmonic balancer of some sort? Nothing is underdriven?
So we're thinking 1lb vs 7lbs of mass is going to generate significant HP?
2014 Audi S5 DSG
2011 335xi Sedan (retired) 2008 335xi Sedan (retired) |
07-02-2009, 11:50 AM | #20 |
27
Rep 1,410
Pullies are great track mods, huge help getting out of the corners. You might see a couple extra ponies on a rear wheel dyno, but the real improvement is on acceleration in the real world. I had one on my 350Z which dropped 4.5 pounds from stock and put down close to 5 rwhp. It FELT more like 10-15 horsepower at the track coming out of a turn onto a straight.
BE CAREFUL installing these, I had mine installed by a friend's friend and apparently he didn't torque it correctly... it came loose and wore out the slot on my crank shaft. I paid Nissan about $3700 to replace my crank shaft since the shaft was no longer useable. It started out as an oil leak, found it coming out of the crank shaft seal, then found out the pulley had almost broke free from being loose. Great mod! Just make sure it is done correctly, like seriously you might want to get BMW to do it. Excited to see this finally avaialbe for our cars |
07-02-2009, 11:53 AM | #21 |
290
Rep 28,154
i believe the n54 is an internally ballanced crank engine. i could be wrong tho.
07-02-2009, 11:54 AM | #22 |
Seasoned Lurker
Rep 160
