Long cranks on 328's ???
07-01-2009, 03:10 PM | #1 |
Rep 17
I have an 08 328 with 12,000 miles and for the past week have been having long cranks. It used to start right up (first 11,000 miles) now it is taking 2-3 seconds when I first crank it in the morning.
Anyone else had this issue on a 328? |
07-01-2009, 03:32 PM | #2 |
82
Rep 1,615
Drives: '11 E92 335i
no... not yet... I'm at 14K miles now... hmmm... I'll keep an eye on that one...
07-01-2009, 04:22 PM | #4 |
48
Rep 1,162
Drives: E90 328i 6MT
07-01-2009, 05:39 PM | #6 |
Been There, Done That.
652
Rep 4,728
Sometimes. When I haven't started the car up for awhile.
07-01-2009, 05:51 PM | #7 |
Rep 22
i got an '08 328xi and i only drive it on the weekends , whenever i start it after 5 days of it just sitting there it usually does that , dont think its anything to worry about , i got 14k on mine. Loving the car by the way, dont give a rats ass that its not a 335 im not a street racer and its pretty quick if u ask me
07-01-2009, 05:57 PM | #8 |
Rep 22
also thought i would give u another good note, a non-turbo car is always gonna be more mechanically sound than a turbo, i think there is alot of people with 328xi that love there cars but they arent like the 335 owners that think theyre drivin around in ferrari's
07-01-2009, 06:46 PM | #9 |
1821
Rep 5,337
07-01-2009, 07:35 PM | #10 |
342
Rep 1,325
Normally long cranks are due to fuel pressure bleed-down. The car normally will maintain some pressure in the fuel system while it sits. A car with a leaky fuel injector or a leaky check valve at the fuel pump (the normal, in-tank pump) will have that fuel pressure bleed off, thus requiring a longer crank while the fuel pump builds enough pressure for the car to run.
If you car runs roughly after a long crank, it normally points to a leaky fuel injector. If it runs cleanly, the fuel is probably leaking back to the tank. I've never driven an E90 with the push button start, but try to turn the car "ON" (not "start", however you do that in this car) for a few seconds, then off. Repeat the cycle four or more times. Everytime the ignition is turned "ON", the fuel pump will run briefly to prime the system. Turning it on/off a number of times will fully build-up fuel pressure, thus allowing an instant start. See if this helps. Another way to test for residual fuel pressure is to find the "schrader" valve test port on the fuel rail. Press it (only with a cold engine) and see if fuel squirts out. My E36 has a schrader valve, but I think that's rare for a BMW, so you might be out of luck on this little test. I don't know what other BMW engines have this valve. |
07-02-2009, 12:34 PM | #13 | |
One cam is enough
130
Rep 6,801
And just because N52's don't have the HPFP, that doesn't mean their pump can't fail from time to time. |
07-02-2009, 01:08 PM | #14 |
13
Rep 193
07-02-2009, 03:10 PM | #15 |
210
Rep 2,110
16K miles. No long cranks here
2015 335xi | Mineral Grey Metallic | Black Dakota Leather | NAV | SportLine | ZPP | ZDA | ZCW | Munich Build Retired: 2008, 2011, 2013 328xi |
07-02-2009, 03:56 PM | #16 |
1821
Rep 5,337
07-02-2009, 03:59 PM | #17 |
SpOoLiN
11
Rep 81
