Engine break-in period?
06-30-2009, 10:12 PM | #2 |
670
Rep 4,959
I don't know if you have tried this yet, but a quick search of the forum will most likely yield a plethora of information discussing break-in theories/beliefs/recommendations.
Some will suggest taking it easy for the first 1,200 miles or so, following any manufacturer-related break-in recommendations, while others will suggest a "hard" break-in that requires you to drive the car like you stole it. I prefer the hard break-in method. If you go this route, just make sure you allow everything to warm up properly (including tires) before you start getting aggressive. Welcome to the forum.
Current: '23 G20 M Sport 330i
Current: '20 X253 GLC300 SUV Gone: '20 W205 C43 Sedan Gone: '18 W205 C43 Sedan Gone: '13 W204 C63 Sedan |
06-30-2009, 10:37 PM | #3 | |
Magical Pill...
157
Rep 12,775
06-30-2009, 11:59 PM | #4 | |
62
Rep 1,736
Drives: '09 E92 335i
| 6MT | ZSP | ZPP | |
07-01-2009, 01:34 AM | #6 |
24
Rep 283
Drives: 2009 E90 335i
I followed the manuals break-in instructions and took the time to let the car warm up and down before starting and stopping. I let the cars rpms drop to 700 before putting her in gear. I officially passed break-in a few weeks ago and I'm glad I was patient. Been driving aggressive and in DS a lot ever since. Waiting to pass 2000 miles before doing in WOTs though.
2009 E90 335i 6AT / Procede / Vishnu DCI / Space Gray / Oyster Dakota Leather / Light Burl Walnut / / Sport, Premium, Cold Weather Pkg / Paddle Shifters / iDrive / Logic 7 / Park Distance / Comfort Access / iPhone Port/ |
07-01-2009, 07:53 AM | #10 |
161
Rep 7,377
today's engine dont need brake in. just warm it up before pushing it.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
07-01-2009, 05:07 PM | #11 |
23
Rep 1,179
its surprising how the comment differ on this subject.. maybe that is what the OP is asking.
i have built many engines in my time, rangiing from low horsepower 4cylinder to tire shredding big blocks and i have to say, a reasonable break-in period is OK .. but if your wondering if it necessary? -- the answer is NO.. will it make you feel better letting the engine temp warm up a bit, since most car manuf. say drive away after starting -- but will it be a deal-breaker? -- NO ************************************************** ******** note: these cars are not port injected engines which enrich the fuel mixture (cold start) at the intake port and are usually trying to overcome a "cold" lean condition, direct injection fires the fuel into the comb chamber with out mixing air and fuel (outside of the comb chamber). so the mix is a lil richer, the car seems to stumble just a bit .. and the exhaust sound a whole lot different -- louder cuz the secondary air pump is dropping a ton of outside air into exhaust system to warm up the cats. the exhaust flap closes off the exhaust pathway to one muffler, limiting the flow -- again, to let to catalysts to warm up quicker. letting the car warm up for 30-45secs couldnt hurt ************************************************** ******** varying the engines RPM range and putting the car under different load conditions may be good.. not trying warp speed blast @ wide open throttle in the first thousand or so miles may be good .. letting the engine have a short cool down period prior to shutting the car off .. well, it could help dissipate heat and allow the block to cure properly (see that its a new casting that gone through a few test bench runs at the engine assembly facility) couldnt hurt. is it required? --NO but the fact remains -- you can drive it like you stole it -- or treat gingerly and never see the cars true potential ... its been my experience that you car is not going to feel "real good" for probably 5-6km -- i'd go with your gut feeling -- whatever that may be |
07-01-2009, 05:13 PM | #12 |
32
Rep 867
I agree. Once the rings seal it doesnt really matter...
Not only will it kill you it will hurt the whole time while you're dying.
http://www.stevesnovasite.com/ http://www.jalopyjournal.com/forum/ http://www.garagejournal.com/ |
