E93 Convert Roof problem
06-30-2009, 10:07 AM | #1 |
Rep 17
hi I am driving a 335i Conv E93 2008 , my roof is closed, but keeps on giving me indication on the dash screen that "roof is not latched". and now my windows can not open or close and my trunk cant open without the key's I don’t care about using my roof any more, how and what can i do so that i can just operate my windows and trunk again?? Can any one please give me advice? Thanks.
06-30-2009, 10:27 AM | #3 |
Rep 17
yes
yes thanks for the replay, if i play around with the button and the sensor switches in the trunk, it starts opening, but is completely confused. the sequence is also out. so that why i don’t want to use the roof any more, and just want control back over my windows and trunk.
06-30-2009, 10:29 AM | #4 |
45
Rep 2,575
Drives: '73 2002,'18 X5 35d,'17 328d T
sounds like the roof sequence needs to be reset. I'm not sure if it's something that you can do yourself or you have to bring to a dealer. Hopefully a Tech will chime in on this for you
1988 E28 535is Euro Conversion --- sold 2009 E90 335 6MT --- sold 2003 E39 540iT Msport --- sold |
06-30-2009, 10:32 AM | #5 |
46
Rep 591
sorry dude, I don't know what to tell you except take it to the dealer.......did you check the trunk to see if there's anything sitting on either side? You know, the area near the wheel-wells where you're "not supposed to put anything on".....? Also, I know this is gonna sound retarded, but try driving over a bit of a bump......I had a weird problem with my roof once after having my suspension installed, and when I drove over a bump, it corrected itself!
SG | Coral Red | 6MT | Sports Pkg | CA | PDC | KWV2 | Dinan Stage II | Morr VS8 | Aero Lip |
06-30-2009, 11:59 AM | #7 |
13
Rep 235
Drives: E93
is your car not sitting on a level driveway?
i had a little issue once when i was on a bit of a sideways slant, and the car frame may have been twisted just a bit and then it didnt latch properly. just a thought
E93 335i Space Grey/Coral Red w poplar Grey/Sport/Nav/Usb audio/Comfort Access
07-01-2009, 06:36 AM | #9 |
863
Rep 5,448
Do a quick search, someone posted the roof reset which involved unplugging and replugging the control modules one of each side of the car behind the backseat - maybe disconnecting the battery for a while would do the same thing, not sure, but if you have warranty still, I wouldn't screw around and just have the dealer fix it.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
07-01-2009, 07:20 AM | #10 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
i wold not take any chances w/ it myself. dealer time all the way, GL.
03-03-2015, 05:07 PM | #12 |
BMWCCA 149159
38
Rep 847
Red light down means the top still thinks it is in transition. Most likely a bumped hall sensor which would be a trip to the dealer unless you can trouble shoot and check every sensor for location against another E93...
03-03-2015, 05:17 PM | #13 |
21
Rep 268
Hey .. It sounds like what I went through ...my hydrolic pump went on the car.. Mine was stuck open for most of the summer I had to pay the dealer to diagnose the issue and close it .. Like I sad mine ended up stuck in the open postion .. I had to waite a week for the trunk to close
03-03-2015, 08:41 PM | #14 |
BMWCCA 149159
38
Rep 847
This might help you locate the sensors.
http://www.bimmerfest.com/forums/att...0&d=1400272366 |
