BMS downpipe fix
06-29-2009, 11:45 PM | #1 |
MEFAKED
Rep 51
BMS downpipe fix
I installed my BMS downpipe fix today and i drove for 75 miles and i still have a SES light. I had my catless downpipes installed a week ago. Will the o2 sim not work if the SES light is already on?
TIA |
06-30-2009, 12:05 PM | #4 |
38
Rep 565
Its just a click away. Best thing I did was buy one.
Thanks for the thread though I just got worried as I ordered the fix. Let us know if clearing the codes does the trick.
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63 |
07-01-2009, 07:32 AM | #8 |
164
Rep 2,875
^^ Yes, I'm running the extra resistors(?) in my O2 SIM right now from RR......At first, after the install of my catless DPs and O2 SIM, the SES light was on and stayed on for a few days, and then it all of a sudden went away..........Came back once or twice a few weeks later, then went away again.
So the first time that happened, I double checked the O2 SIM wiring to see if anything's loose or connected incorrectly. As long as it's installed correctly, you might just need to clear the code or let it run a few more days and once the car goes through a few cycles, the SES light should turn off..........Or ask the vendor you bought from for extra resistors to add to the O2 SIM (probably the last option). GL, hope this helps.
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
07-01-2009, 09:25 AM | #9 |
38
Rep 565
Excuse my ignorance but does the o2 sim from BMS have different settings or is it only a plug in device with nothing else to change?
I have seen my tuner turn of the second lambda via flash tuning on other cars and is basically a few bites in the software which is the simplest route but I also like having a back up in case he can't get it right for whatever reason.
09 C63 |
07-01-2009, 09:50 AM | #10 |
3072
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
happened to me as well.
1. get the codes cleared. im going to be investing in a BT scanner myself. 2. recheck the wires and make sure it's installed correctly. apparently i installed it in the wrong row of the black connector (it was my first time with pin out). I haven't gotten the SES light since. I've driven it decently hard as well as set it to cruise control. No light so far. After a clearing/installing properly you shouldn't have an issue. The adding of resistors would probably the final solution, but I haven't seen THAT many cases of people doing it in the first place. good luck!
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
07-01-2009, 12:43 PM | #12 |
MEFAKED
Rep 51
I emailed Terry about it and I even emailed him a picture of the install to make sure I did it right. He also recommended a BT but there are a few other important things I need money for before the BT so idk when I'll have the money for it.. Thanks again guys!
07-01-2009, 12:47 PM | #13 |
84
Rep 1,575
I think that you got to use a different pin if you dont use a JB tune.
Which pins are you using?
Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge Space Grey 335i -> See more pics HERE |
07-01-2009, 03:54 PM | #14 |
164
Rep 2,875
Or you can just get a PROcede Rev.II which COMES with the DP fix......
07-01-2009, 04:18 PM | #16 |
MEFAKED
Rep 51
07-01-2009, 04:52 PM | #17 |
164
Rep 2,875
^^ Seriously, just double check your connections, re-do the wiring and start from square 1 if you have to......That's what I did to eliminate the possible causes........IMO
07-01-2009, 05:57 PM | #19 |
164
Rep 2,875
And the SES light is still on? I finally did get an el cheapo C-reader that clear codes.
Worked like a charm. If you don't want to buy that, then like others have mentioned, go to Autozone and have them clear it.
07-01-2009, 07:14 PM | #20 | |
Joint Chiefs of Staff
4918
Rep 115,980
The downpipe fix or o2 sim does not clear the codes, it only prevents them. Once stored in the cars system they need o be cleared! Mike |
07-01-2009, 09:45 PM | #21 | |
MEFAKED
Rep 51
Ya I read the guide but I must of missed that part... Thanks for clearing things up!
