Does one even NEED an intake?
06-28-2009, 05:26 PM | #1 |
923
Rep 15,818
As some may have noticed, I have posted several topics relating to intakes in some way or another...
well this is because I don't want to send X dollars without knowing if it's worth it (as I am sure many understand) If I am going to be running a PROcede Rev2, and other than that, I don't see myself getting an exhaust or downpipes (at least not in the near future) so... would I even need to change from the stock intake? (whether it be injen afe stett etc) Thank you and sorry for being such a nuisance :P |
06-28-2009, 05:31 PM | #3 |
82
Rep 1,389
If looks and sound are important to you, then yes, a dual cone or cold air induction will help. Performance-wise, it's debatable. Similar results have been achieved with both a high-flow drop in filter, dual cones, and CAI.
"SYONRA" is for sale! http://www.e90post.com/forums/showthread.php?t=366678 BSM '09 e92 335i | Performance: JB3, RR Catted DP's, INJEN DCI, Britalman Exhst, AA FMIC, FORGE DVs | Suspension: ST-V1 Coils, Hotchkis Chassis Brace & F/R Sways | Wheels: Bremmer Kraft BR03s, Brake Performance Rotors, Cool Carbon Pads, ECS Lines | Exterior: OEM Aero Lip/Rear, ****** CF Trunk Lid, BLUX5 Angels, M-Force M3 Sides | Interior: Passport 9500ci, Black Trim, M3 Wheel
06-28-2009, 05:43 PM | #4 | |
923
Rep 15,818
performance gain (like hp gain) not that big of an issue as much as allowing my engine to run without (or less) problems due to increased air flow. but if the stock one is enough or more than enough.. then much of a point in that area sound is nice, but is it worth a 170/280 dollars? debatable... I'd rather get a smarttop if sound is the only thing... its just that my car runs at an avg of 240 degrees even without a procede so i'm scared that it'll run much hotter when I do install it... |
06-28-2009, 05:44 PM | #5 | |
82
Rep 1,389
06-28-2009, 05:58 PM | #6 |
11
Rep 273
dude, you've already made up your mind that intake isn't worth it. so why do you keep asking us to convince you otherwise if you aren't taking anything we say seriously.
06-28-2009, 06:00 PM | #7 | |
185
Rep 1,640
06-28-2009, 06:06 PM | #8 | |
923
Rep 15,818
yet, i cant complain that the main questions on my mind now are what to do and what not to do and what should i do etc regarding my (already amazing) car.... Thank you all for the information Intercooler does make the most sense. I have only recently joined this forum and have learned a great deal of important and useful information from fellow members. Thank you all again. |
06-28-2009, 06:10 PM | #9 |
Just some guy
49
Rep 1,531
be a man. make a decision. stick to it.
2008 BMW 335i/Sedan/Alpine White/Terra/Steptronic/Premium Package/Sports package/Comfort Access/USB/Sirius
06-28-2009, 06:10 PM | #10 |
865
Rep 5,450
You would need pretty big HP before the stock airbox won't flow enough - south of 400, until then, the stock airbox and a drop in are just fine and generally will be getting cold air better than dual cones.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
06-28-2009, 08:01 PM | #11 |
30
Rep 1,748
He's right on the money, more or less... An intake makes great noises under the hood, and might give you a small bit of hp on the high end, but they really don't do much else unless you are running a 400+ HP engine. Better off with stock or even a drop in filter... Personally I'm getting a K&N drop in filter, after warranty ends (Aftermarket FMIC and Oil Cooler)... If your worried about temps, that's what you should do as well...
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi) 2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune |
06-28-2009, 08:04 PM | #12 |
923
Rep 15,818
Thanks.
I'm not worried about my warranty ending... thats 4 miles/50k miles... and I'll be out of the car before then most likely... life is short.. gotta drive as many beautiful cars as I can...my goal in life actually.. |
06-28-2009, 08:11 PM | #13 |
Night Sh1ft
458
Rep 3,079
Drives: F95 X5MC LCI
as with any forced induction car, the more volume of air you can get into the system, the happier your engine will be. While the temperature coming in from the intake side is important, test results shown give the stett cai a few degree F advantage, which doesnt really translate into much difference vs a DCI if you consider going through the fmic as well etc. Overall, when your engine needs more air, the stock airbox will be limiting you. While you may not need more of that air now, as soon as you strap a tune on your car and are essentially adding 80% more boost, a little more air is beneficial, even at the expense of a couple degrees higher intake temp.
all in all...get FMIC...it makes a huge difference on AIT in comparison to the intake, which you need to increase volume of air brought into the system sadly its not a simple answer
"Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson |
06-28-2009, 08:14 PM | #14 |
///M Specialist South Shore BMW
770
Rep 7,108
why not find out for only 100 bux?
http://www.e90post.com/forums/showthread.php?t=277015 the sound is really cool, with a high powered tune it can make a difference but not big from my experience.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
06-28-2009, 08:26 PM | #15 |
43
Rep 1,210
If you don't want to spend a ton, go and pick up two dual cones from Autozone or Pep Boy's and make your own. Take off your stock box and put on your two cone intake filters on the intake hoses, clamp and your done. There is a DIY somewhere.
06-29-2009, 06:03 AM | #18 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
just go w/ a up graded drop in, and call it a day.
06-29-2009, 06:16 AM | #19 |
307
Rep 5,175
Why don't you guys ask Terry what the wastegate duty cycles look like on a tuned car with the stock intake. I think you will quickly find that running a tune on the stock intake is not a good idea.
06-29-2009, 08:42 AM | #20 |
196
Rep 832
Drives: 2019 G01 X3
I've seen a few people on this thread recommend a drop-in filter. Are these really better than the stock OEM filter? If so, which ones are people finding to be actually better (K&N, Helene Streamline, BMC, ITG, aFe, Macht Schnell)?
06-29-2009, 08:47 AM | #21 |
307
Rep 5,175
The funny thing about drop-in filters is that they were dyno tested and showed no gains, but no one seems to believe the dynos. It is kind of odd.
06-29-2009, 10:04 AM | #22 |
30
Rep 1,748
Only good thing about a drop in, is you clean it and re-oil it and drop it back in again, don't have to worry about buying a new filter every 20-30k miles...
