Weird Noise?? Boost leak?
06-28-2009, 02:01 PM | #1 |
13
Rep 212
UPDATE,at bottom of thread. Just ran the PROcede data log feature. Need some help!!
So, Driving the car today with the windows down i notice under a load, or aggressive acceleration, i can hear a very loud hissing noise coming from what sounds like directly under the engine bay. I have never heard this before and it is VERY LOUD! Louder than the exhaust, engine, and wind combined. However, I have never really punched it with the windows down. Is this normal? The only logical thing in my mind is maybe the wastegates venting, but our cars vent into the system and not the atmosphere... correct? My only other thought is that i recently put in a K&N filter... could i be hearing the turbos spooling? But that doesn't make much sense as the intake is a closed unit.... No codes, no cautions, just noise.... Anywho, those that are far more experienced than i please let me know what you think. Thanks
Rides
2015 Toyota Tacoma 4x4 2003 Yamaha YZF-R1 SOLD 2007 335i Sedan Titanium Silver Metallic Last edited by ptwob311; 06-30-2009 at 08:40 PM.. |
06-28-2009, 03:41 PM | #2 |
27
Rep 1,410
I have heard some say even a K&N drop-in filter will slightly increase turbo sound. Biggest question is, are you running a tune? I would find it hard to believe you are hearing stock boost. If you are running higher boost (like 12+ psi) maybe you are hearing the turbos and/or the diverter valves. They still vent, just closed loop so quieter.
Also if you are running catless DP's those can hiss a bit, but not as noticeable as test pipes (cat deletes) on a N/A car where you hear it hiss when you let off the gas. |
06-28-2009, 03:46 PM | #3 |
61
Rep 939
Definitely sounds like induction noise but you say you still have the OEM intake, correct? Maybe, the top is not on all the way. With DCIs you will hear a loud hiss under load or during acceleration. Recheck the lid of the intake.
06-28-2009, 04:34 PM | #4 |
13
Rep 212
I have the PROcede installed (standard map for stock 335) and yes, the OEM intake is completely closed. It just seems like a LOT of air is being forced out of something (diverter valve...etc) on the bottom side of the engine bay. A very loud hissing above 3K RPM. It was louder than the road noise and other cars at 40 MPH. Although i could not get it to replicate sitting still in my garage.
Actually I bet other cars probably think i have a giant air pump propelling my car down the road. Thanks for the replies.. I am just trying to gauge whether this is something i should be worried about/take it in to BMW as the car only has 20K on it.
Rides
2015 Toyota Tacoma 4x4 2003 Yamaha YZF-R1 SOLD 2007 335i Sedan Titanium Silver Metallic Last edited by ptwob311; 06-28-2009 at 05:09 PM.. |
06-28-2009, 05:38 PM | #5 |
32
Rep 1,786
Check all connections where you could have a boost leak,like the intercooler connections,by the throttle body area,the diverter valves,etc.If have someone who knows how to do a boost leak check thats the way to go.It can be done with a bicycle tire pump.All you need is like 12-15 psi to check for the leak,and listen to where its coming from.
06-29-2009, 11:35 AM | #6 |
13
Rep 212
Thanks, I'll go look at the car in the garage... check all the connections and such
If i had a boost leak at any of the above mentioned locations would that throw a code? Just seems odd that if the connections are spilling enough air to make that much noise the car would not detect that somehow. does anyone else ever hear this when driving?
Rides
2015 Toyota Tacoma 4x4 2003 Yamaha YZF-R1 SOLD 2007 335i Sedan Titanium Silver Metallic |
06-29-2009, 11:58 AM | #7 |
29
Rep 703
i mean i have a jb3 and before i put my DCI on if i had the music off and windows open i could def hear the turbos spool up and release upon accelerating or load. i drove around for 3 months with a tune only and could hear them with no codes or errors not loudy but if i listened for them i could def hear it. but now with the DCI i hear them very loudly and love it.
06-29-2009, 05:06 PM | #8 | |
654
Rep 10,587
if your losing enough air to hear it, you should throw a code. I found the 335 to be very tempermental w boost leaks. do you have a boost gauge? Since you have the procede hooked up can you datalog and check your boost logs? If your spooling quickly and holding your target boost without any dips thru 3rd gear, chances are you do not have a leak. or look up my post on a boost leak test and give that a shot. best of luck
06-29-2009, 06:53 PM | #9 | |
13
Rep 212
I guess i should be a little more descriptive of the sound. As i accelerate and build boost (along with RPMs) the whoosing noise grows louder and louder. Sounds like a cubic ass-ton (actual scientific unit) of air is being forced somewhere. Not sure if that is actually out of the system and into the atmosphere... or just echoes thru the intake.... but with OEM box that seems highly unlikely.
Rides
06-29-2009, 07:23 PM | #10 | |
654
Rep 10,587
best idea would be to drive/hear another stockish 335. and do those Procede logs
06-29-2009, 08:14 PM | #11 |
13
Rep 212
absolutely, only problem is.... i don't know anyone in my area that has one. I have only seen a few.... Maybe I'll try the rocky mountain forum. Thanks for your help
Rides
06-30-2009, 09:06 PM | #12 |
13
Rep 212
OK, SO, i ran the PROcede data logging application and here is what i get.
First off the noise is definitely coming from the turbos or really close too em. With the windows up it was much easier to pinpoint the location of the whoosh/hissing. I am almost completely certain it is coming from somewhere near the passenger side of the engine bay by the tire somewhere. (Surprise surprise... exactly where the turbos are!!) With the PROcede off i am only building 6.8psi; it tends to stay in he 4-6psi range. With it on (setting from Vishnu) i get about 13psi peak and it tends in the 5-8 range. I will attach the graphs. Also, The car keeps giving me the Half lit engine in the caution light area. I got the code 83 and 90 to pull up on the PROcede, from the CANbus channel... but i can not find where to turn that into a BMW code. Anyone know what these mean? i am kinda new to the whole turbo tuning thing and i am almost certain this is clearly a boost leak.... but as i have stated before there are those out there far more skilled and experienced than I. To those please let me know what you think. Should i take the car in?? First two graphs are boost and RPM with PROcede OFF. Second two are PROcede ON
Rides
06-30-2009, 09:16 PM | #13 |
654
Rep 10,587
got ur PM, pretty darned sure thats a boost leak.
curious what the codes you are getting mean. now to find it. start looking closely at all connections and there is a good chance that you can find it just by looking for small amounts of oil/oil vapor collected at the connection. pressurizing the whole system is a more thorough approach.
06-30-2009, 09:22 PM | #14 | |
13
Rep 212
Also, I gotta find where the codes are listed by Vishnu.
Rides
07-01-2009, 04:12 PM | #16 |
Rep 33
09-08-2009, 10:40 PM | #17 |
Chemo Doc
Rep 470
which exact tube did u find the crack in? was your issue fixed?
jet black 335i, 6MT manual, black interior with silver aluminum trim, PP, SP.
09-25-2021, 08:02 PM | #18 |
Rep 1
Pls help new n54 owners here and really need some help
So I just bought a 2007 e90 335 6mt ,I wanted a 335 for years but I was just too afraid to buy one ,everyone told me not to buy one because they are super unreliable ,the car has 81k miles bought it at 79k miles I bought the car for 7 k from some older gentleman , being super paranoid I did a lot of stuff to the car before I started tuning it,I change the indx 1 that where on the car with index 12 ,valve cover gasket, ofhg,serpentine belt and pully's,7.5 vrsf intercooler down pipes,and a tile bov the car had this noise even before I start to do al the maintenance ,and I can't figure it out what it could it be it's like a hissing noise when I let of the throttle ,and it's not the bov
09-25-2021, 08:42 PM | #19 | |
201
Rep 713
can you start your own thread and describe exactly what is going on ? I mean when the hissing starts ? if the hissing is when you let off the throttle after boosting, it's likely to be a normal sound of the BOV, it just dumps the excess of boost and it does a "woosh" sound.
beter laat dan nooit
