Need Help Justifying Coilovers
06-26-2009, 12:03 PM | #1 |
424
Rep 4,709
I was planning to get the Eibach Pro Kit / Koni FSD combo and have been asking around what are good setups. A lot of people also tell me I should get coilovers with adjustable dampners. So, I looked into the KW V2, which is about $700 more.
Is it really worth it? I am looking for maybe a 1-2" drop (a tad more in the front than rear) along with having a more responsive feel for the road. I plan to attend one, maybe 2 track events per year after all is said and done. I would prefer not to have to adjust anything, unless the effort would make a big difference. This is my DD year round. |
06-26-2009, 12:31 PM | #2 |
Night Sh1ft
458
Rep 3,079
Drives: F95 X5MC LCI
kyle..I went through the same questions for myself
ultimately, I couldnt justify the cost of the coils vs the eibach/pro-kit because the performance would be similar on a day to day basis, edge to the eibach/pro-kit on the daily commute b/c of its twin tube design for a bit more comfort when not being pushed...and edge to the coils on those two track days for firmness. but what preference you have....thats all you brotha
"Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson |
06-26-2009, 01:30 PM | #3 |
424
Rep 4,709
Yep. I think I am just going to do that. I was just looking to see if anyone had any compelling argument for the coilovers. My preference, though, is still the former.
06-26-2009, 01:53 PM | #4 |
375
Rep 17,017
If you are after a lower ride and better performance, there is no reason to do coils. The only times I recommend coils over a standard spring/shock combo is if the customer is adamant about adjustability or they track the car regularly and need the ability to dial in specific suspension settings. For most, a spring/shock combo is more than capable of offering the benefits of a coilover without the risk of configuring the suspension incorrectly.
You have to decide if you will really use the adjustability of the coilovers and if the premium is worth it. Some, like myself, prefer to have that ability but it's not entirely necessary IMO. |
06-26-2009, 01:58 PM | #5 |
82
Rep 2,325
The ride height adjustibility can prove invalueable. If you end up getting wheels later on and the offset is slightly too aggressive, just raise the car a bit. Or...if the offsets are "right", you can slam it if your taste changes. I had H&R Sports on my E46 and switched to coils, never looked back. Went coils within 6 months on the E90 and I couldnt be happier.
| Andrew | M Technik | BMW Performance | BBS | Forge | V1 | LUX | Bilstein | Precision-Sport |
06-26-2009, 02:54 PM | #6 |
475
Rep 13,583
Drives: JB E92 335i
Well the obvious answer to the advantages of the coilovers are the ability to have matched lowering springs and shocks combined with added beneifit of adjustable ride height and spring rates.
What else can they do , well they'll typically reduce unsprung mass, suspension travel is often increased through the new arm. Plus the car can be corner balanced (weight is moved around on the car and height is adjusted until the cars cross weights are even). With the V2 you mentioned - you'd also be able to adjust your rebound dampening, setting the shock to your liking. |
06-27-2009, 11:46 PM | #8 |
Gruppe Titan
262
Rep 2,839
Drives: 08 E92 SG/Coral
I was in the same boat as you. H&R springs/Koni yellow were close 650-750 bucks. I decided to spend $100 more and get FK Highsport coilovers. They are only height adjustable, but that's all I wanted.
I'm 100% happy that I can adjust my ride hide according to the roads here. With springs your pretty much stuck at the height they drop it to. Contact Supreme Power, I can bet that you will be surprised at how affordable FK coilovers are.
06-28-2009, 02:44 AM | #9 | |
Night Sh1ft
458
Rep 3,079
