Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Limp mode 1 week after install of JB+!?
      06-26-2009, 07:27 AM   #1
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
On the way home from work yesterday I got the dreaded "Engine Malfunction: Reduced Power" message. Has anyone else gotten this with their only mod being JB+, not altered from the factory middle setting?
Is it almost certain that since it induced this limp mode I have a code thrown?
The circumstances: It was very hot and humid here when I was driving home, I had the A/C on "Max" for parts of my drive (only about a 20 min drive) and the engine malfunction message appeared in the last 5 minutes or so, after some WOT driving and possibly not fully warmed up yet. I got the message while I was about to pull off the highway and honestly, the "Reduced Poer" didnt feel nearly as reduced as I would have expected. When I got off at my exit and there was a red light I turned the car off and on again. No long cranks although the idle seemed/seems a little rough (then again this seems to be true of bone stock n54s).
Any thoughts? My main concern is that I threw a code.
      06-26-2009, 08:15 AM   #2
e90southfl
Drives: 2008 335i
I started having the same issue over the last couple of weeks with my SSTT. I am down in Miami and it seems ever since its gotten warmer and more humid, I go into limp mode about once every 2 weeks. The code I have been throwing is this one, always at the same RPM too...
30FF:
30FF Exhaust fume turbo charger, low pressure side
Error will not cause a warning light
Error is not currently present
Test conditions have been completed
Event 1Odometer 53152kms 33027miles
ambient pressure 997.66 hPa
ambient temperature 27.75 °C
pressure in front of throttle valve 134.00 kPa
speed 2,048.00 rpm
If I remove the SSTT, I do not go into Limp mode. I was running the JB1 for months without issues.
      06-26-2009, 08:21 AM   #3
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Pisses me off I feel like I have to shell out the money for the BT scanner now, I wouldnt have gotten the JB+ if I knew these issues were going to come immediately.
      06-26-2009, 08:29 AM   #4
theanhdy
theanhdy's Avatar
94
Drives: 135i
BT scanner is a great tool to have if you're running any tune no matter how mild it is, hell I would even get it if I'm stock because the N54 has so many weird random issues. People get LIMP MODE even when they're stock so don't freak out until you pull the fault code.
      06-26-2009, 08:39 AM   #5
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
I will be the first to admit I am no expert when it comes to these tunes. But I dont think it takes an expert to go out on a limb and point the finger at the tune when I have 16k+ miles on the car with zero problems and zero limp modes and then a limp mode within a week of adding the tune. Dont get me wrong, I knew this was a realistic possibility when I ordered, but that doesnt mean I am happy about it.
      06-26-2009, 09:17 AM   #6
Zeph
27
Drives: 2008 E92 335i 6MT SGM CR/BD
Don't forget the HPFP. You are putting more load/stress on it now, causing a known weak part to possibly be getting esposed now (when you WOT).
      06-26-2009, 09:35 AM   #7
TurboBimmer
TurboBimmer's Avatar
Luxembourg
79
Drives: F82 M4
30FF:
speed 2,048.00 rpm
+1 I experienced the same thing twice over the past 2 months with the JB+. Same rpm range, same code. Weird...
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
      06-26-2009, 09:37 AM   #8
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Strange, I havent read about this specific issue on here before with just the SSTT/JB+ level tunes. Did both of you just use the BT tool to clear the codes? Have either of you been in for service since the limp?
      06-26-2009, 09:38 AM   #9
ducati955
ducati955's Avatar
90
Drives: lifted tacoma on 38's & ducati
2007 BMW 335i  [10.00]
so what do u guys do when u go in limp mode? sorry if its a dumb question, i just wanna know in case, cause i plan to get a jb3 tune
car totaled out !!AW335i, oem aero lip, m3 csl rims, oem m3 sides, vorst csl carbon trunk, tinted, lowered on H&R sport, AR DP's, Bastauck dual exhaust, BMS intake, etc
NEW RIDE white GTR!
      06-26-2009, 09:43 AM   #10
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
I'm not sure if there are 2 levels of limp mode (can anyone explain exactly what limp mode does mechanically, does it just disengage the turbos?), I know some people say there is a lot of shaking and such, but I was able to drive essentially normally for the minute or 2 it took to get to a red light and I just turned the car off and then right back on and everything was fine.
      06-26-2009, 09:45 AM   #11
TurboBimmer
Luxembourg
79
Drives: F82 M4
Just shut off and restart the car. Then everything is normal again. It's really weird because it happened when cruising at normal highway speeds. Not at WOT pulls. Apparently this code refers to a boost leak. But my car is stock otherwise
      06-26-2009, 09:48 AM   #12
Zeph
27
It seems like limp mode (1/2 full engine icon) just cuts boost because the car feels much slower maybe like a 330i with a poor tune. If you get the 1/2 engine + SEL (service engine light) then you really have like no power and maintaining 50 mph on the interstate is hard to do.
Just pull over and shut the car off, wait a minute and restart it. This usually cures the LIMP mode. If you get SEL then I had to go to the dealer and have my HPFP replaced, could not clear that light.
      06-26-2009, 09:51 AM   #13
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Thanks for the info, that's exactly how it felt (1/2 engine icon only) - I had no problem maintaining 55ish for a minute until I reached my exit.
      06-26-2009, 10:13 AM   #14
RambleJ
RambleJ's Avatar
No_Country
60
Drives: F10 535i M-sport
30FF:
speed 2,048.00 rpm
I beleive that error code is a possible boost leak...
      06-26-2009, 10:22 AM   #15
e90southfl
Drives: 2008 335i
Same thing, turn the car off and on, and its all good. I know the code indicates a boost leak but I highly doubt it. Its always thrown under a very light load, at a low rpm, SAME rpm, and never thrown with the tune out. I track my car heavy (without the tune) so if I had a boost leak, it think I would throw a code after 45-60 minute track sessions in 90+ degree heat, which it hasn't yet.
      06-26-2009, 10:45 AM   #16
NRG
NRG's Avatar
Russian Federation
36
Drives: 2012 X5 35d
I think it's best for you to contact BMS tech support instead of shouting it out over the forums. Terry will most definitely help you resolve that problem in a flash.
Retired: 2005 N52 E90 330i Sport 6AT
Retired: 2007 N54 E92 335i Sport 6AT
Current: 2012 M57 E70 X5 xDrive35D
      06-26-2009, 10:50 AM   #17
golfinz
235
Drives: Tanzanite M3
Why not just take the jb+ off and take it to a dealer?
      06-26-2009, 10:53 AM   #18
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Yeah its not so much that I am concerned about the car breaking down, I think its clear simply restarting the car clears up the engine malfunction. My main issue is I am concerned about taking it to the dealer next time now that this code is likely thrown (and I really didnt want to shell out another 300 for the BT scanner).
      06-26-2009, 10:55 AM   #19
stressdoc
Moderator
stressdoc's Avatar
Dominica
618
Drives: BMW i8; Toy 4runner TRD pro
For issues like this I think it's often helpful to get input from other owners. This problem may not be limited to the JB+, and could provide useful info regarding hot weather performance. If there is a fix from BMS then that should also be posted if the vendor approves.
      06-26-2009, 10:57 AM   #20
NRG
NRG's Avatar
Russian Federation
36
Drives: 2012 X5 35d
You shouldn't be having any codes in the first place with JB+. On your place I'd get to the bottom of this problem by resolving it with Terry's help.
      06-26-2009, 10:59 AM   #21
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Yeah I contacted Mike@n54tuning who arranged the group buy - maybe this was the wrong person to contact though. and as you said, I really am just looking at input from other owners to see how normal this is at this point.
      06-26-2009, 10:59 AM   #22
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Who is Terry? (I realize this is likely a stupid question)
