Proceede help v3 rev 1 new maps boosting 21lbs wtf?
06-25-2009, 06:35 PM | #1 |
*BluRp*
371
Rep 10,417
I noticed with the new map thats out for the v3, i know its set to user adjustable tq at 75% cause shiv said to leave it at that but i'm only gettin peak boost at 10psi and it holds at 9-10 when i'm at WOT...
is this the way it supposed to perform with the new map?
Blurple has her own Facebook page! Follow her for updates and photos!
www.facebook.com/SEBlurple Last edited by Dr.phuOnger?; 06-25-2009 at 08:20 PM.. Reason: helppp |
06-25-2009, 06:43 PM | #3 |
*BluRp*
371
Rep 10,417
I doubled checked to make sure valet mode is not active.. i even cleared the ecu and then reloaded firmware and reloaded the map and didnt touch anything and left it default...
default valet mode is not enabled
www.facebook.com/SEBlurple |
06-25-2009, 06:49 PM | #4 |
164
Rep 2,875
Wouldn't valet mode induce stock-like boost, which is around 7-8 psi? You can also lower it I believe.
If he's getting 10 psi, it's definitely the Procede working.........Any other mods?
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
06-25-2009, 06:58 PM | #5 | |
*BluRp*
371
Rep 10,417
this problem only happened after i updated to the new map... i'm going to go home and try to adjust my map 1 to like 5psi to check and see if my proceede is confirmed working as it should
06-25-2009, 07:05 PM | #6 |
164
Rep 2,875
You should be running stg 1?
Try running stage 2, or up the UT to 80% and do a test run! I think on stg 1 you're suppose to see 12-13 psi........I would say check for boost leak, but you mentioned this only happened after updating to the new maps.......The 5-29 maps I assume?
06-25-2009, 07:33 PM | #7 |
*BluRp*
371
Rep 10,417
yup 5-29 maps. leme try stg 2 map and see if any diff
06-25-2009, 07:54 PM | #8 |
128
Rep 2,740
Rev 1 or 2?
I asked about valet mode because when I went to rev2, it seemed to have reverted to valet mode for some oddball reason. I thought it was odd that I wasn't boosting to 14-15psi and when I discovered it went to valet mode I had been boosting to around 9-10 psi. EDIT: Sorry... didn't notice rev1 in the thread title
06-25-2009, 08:02 PM | #9 |
136
Rep 1,954
Drives: 2020 X3M Competition
very strange... I have v3 rev 1 and dci + catback running stg 1 as well. Peak recall on my gauge is usually 15.8-16.1.
06-25-2009, 08:09 PM | #10 |
*BluRp*
371
Rep 10,417
okay something is funky... if anyones avilalbe im availble by aim by phuongerr
lol... so i data logged 2 runs 1st run i left it alone for user settings 2nd run i put both maps to 5 psi limit i went out and ran both my data logs showed that i was all over the place for boost both data logs showed my boost hitting all the way up to 19 at some points only at a fraction of a second then it would drop back down it never capped out at what i set my limit.. car felt same on both runs
06-25-2009, 09:07 PM | #11 |
77
Rep 418
There must be something to this. I installed the PROcede, new, pre-loaded with non-doomsday maps 5-29. I just had the install about 2 weeks ago, and the PROcede was sent out to me in this last batch. The firmware is 117 and it was all installed by someone who has the PROcede and knows the install and set-up process.
Well, anyways a couple of days ago I decided to open it up and datalog (UT set @ 80%, I am running 93 octane, Stett CAI, and UUC/Corsa Exhaust). When I looked at the datalog for a brief few seconds or milliseonds, the boost shot up to 19psi, 21 psi and 21.3 psi. conseculatively. After those brief spikes it was back down in the middle of the run to what I would think would be a normal 14.6psi. What is causing this?? Doesn't the PROcede CANbus have the boost limit set to 16psi for a reason, how could it get out of that range? Obviously there are other people now with this issue. I am going to be calling Vishnu tomorrow and e-mailing Shiv, but I know he is out of pocket in NY. Hope the is a solution to this as those boost spikes scare the hell out of me. Any help would be appreciated, but again I will attempt to talk with Dustin or Shiv. Thanks. |
06-25-2009, 10:20 PM | #16 |
*BluRp*
371
Rep 10,417
yeah i figured its not normal.. i reloaded the firmware and the maps numerous times..
06-25-2009, 10:22 PM | #17 | |
Member
28
Rep 344
Present - 2016 340i, Alpine White, Black, M-sport, 6-spd, Track Handling, Tech pkgs
Past - 2011 E90 335i, Alpine White, Ivory, Sport, Premium, Steptronic Past - 2008 E90 335i, Titanium Silver, Dakota Grey, ZSP, Steptronic, 6FL, Wagner FMIC, Bilstein B12 Pro-kit, M3 control arms, SS F/R brake lines |
06-25-2009, 11:28 PM | #18 |
Team Zissou
3065
Rep 10,197
You set the max psi to 5? That setting is the max ALLOWED boost, not your target boost. If you go past the "max boost" for a second it triggers one of the safety settings. Turn that back up to 16
You raise/lower boost by adjusting the user torque settings, not that max boost setting. If you want to test out lower boost, lower your torque settings to 0% (for stock like boost) |
06-25-2009, 11:36 PM | #19 | |
127
Rep 2,224
06-25-2009, 11:38 PM | #20 |
127
Rep 2,224
I see Shiv has Stg 1 described as 75% on his upload site, but is that an typo? Shouldn't it be 70%? I'm pushing 15psi @ 75% with DCI, MP and Catback.
06-25-2009, 11:52 PM | #21 | |
Rep 3
Oh, the irony!
06-26-2009, 12:00 AM | #22 |
Team Zissou
3065
Rep 10,197
