Squeaky clutch pedal
06-24-2009, 02:02 PM | #1 |
20
Rep 341
Hi guys,
I have almost 8k miles on my car right now. I have had a squeaky clutch pedal for about 5K miles now, it's really annoying. Anyone else experience this before? If so, any quick fix? I really don't want to drop it off at the stealership just for this problem if it's not necessary. |
06-24-2009, 03:14 PM | #3 |
Rep 167
hmm my clutch has the SLIGHTEST squeak that i can only notice when my car is not moving and engine is off. and i think with the window open.
wheres the sound coming from? lol, i think wrong section for this thread
06-24-2009, 03:34 PM | #5 |
Rep 167
mines a full press, dont know about op
06-24-2009, 03:43 PM | #6 |
Joint Chiefs of Staff
4918
Rep 115,980
I have had this on a car before. It's usually a rubber piece rubbing up against the linkage or something, depending on design. Just take it in and have the dealership look at it.
I had a squeaky steering wheel and they fixed me up Mike |
06-25-2009, 05:17 PM | #9 |
50
Rep 511
The fix is just to spray some lubricant on the clutch spring thingy (sorry I'm not very technical ) - that's what the dealership did to mine when I took it in and it stopped the squeak.
Jack |
06-25-2009, 11:50 PM | #10 |
solid @ 153, no, 155mph!
15
Rep 335
the dealership will lube it but that does not always fix the problem. Mine started with a squeak, and after a couple sprays, turned into a click, got something replaced, the click came back after a couple days and then got something else replaced. It took a few visits but now it's gone, so just get it checked out.
06-28-2009, 09:01 AM | #11 |
Rep 9
It's likely one of the bushings that the clutch pedal pivots on. In the E36's these bushings were known to breakdown. UUC sold replacement bushings that were made of material different that OEM.
Lube will help, but eventually the fix is to replace the bushing. FWIW, I have a 6MT and have a slight sqqqqqueak on full depress that can only be heard with windows up, radio off. |
06-28-2009, 09:28 AM | #12 | |
381
Rep 1,174
Drives: BMW
09-08-2009, 04:44 PM | #13 | |
33
Rep 319
09-08-2009, 10:15 PM | #14 |
177
Rep 6,631
my clutch pedal was making creaking sounds when releasing the clutch pedal around 3000 miles, lubed it up with a lot of wd40, around 9000 miles now, the noise never came back.
E90 LCI N54 6AT
09-08-2009, 10:26 PM | #15 |
198
Rep 3,840
what did you actually lub???
///M |
09-08-2009, 11:13 PM | #16 |
432
Rep 938
I also have this problem...
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
09-09-2009, 12:19 AM | #17 |
33
Rep 319
WD40 would have been useless in my situation. My noise came from within the bell housing where you can't access. A high temperature brake grease was needed.
