Phone Docking Cradle Installation
07-28-2005, 03:29 PM | #1 |
Guest
Rep n/a
Drives:
I drive an '06 E90 with Navigation & Bluetooth installed. I have the system base plate part # 84-21-6-946-075 and the adapter #84 21 0 307 726. Does anyone know where I can get an installation guide? Classic BMW in Dallas, TX referred me to an installation specialist that can't seem to figure it out...it has been a month. The installer says "it appears that we need additional parts"... Thanks, David.
07-29-2005, 04:01 AM | #2 |
Addict
203
Rep 2,074
I've got the bluetooth installed aswell. I've got a "blank" cradle over the place where it is...
If you push the button (circled inred below) remove the blank cradle, the cradle from BMW should just snap in it's place! I hope this helps... |
01-21-2006, 01:16 PM | #3 |
Rep 38
Drives: Interlagos Blue '13 M3 Coupe
My E90 330i Mfg. 10/05 does not have that kind of button. I only have a rubber cover in this center console, so do I have to pull something else apart?
Interlagos Blue 20134 M3 Coupe, Comp Pkg, DTC, iDrive, No other options to keep it light View My Garage - http://www.e90post.com/forums/e90gar...garage&id=7562 |
02-04-2008, 07:14 PM | #4 |
Rep 8
yes you do have to remove the ruber piece.
you may also not have the (3) additonal wires in the back on the drives side under the carpet cover over the wheel, the seems to be missing from the 10/05 producton, my car was produced in the same month. FYI the button in read is apart of the eject box. I did the install also, very quick install. no need to remove the entire console, the required wires can be reached by unsnaping the leather shift boot. you will have access from the drivers side, for the two connection cables. |
02-09-2008, 05:20 PM | #5 |
571
Rep 7,519
Drives: 2009 E90 335i MT
The instructions are in P/N 01 29 0 403 645. My scanner isn't working right now so I'm going to enter all of the steps here for E90/E91.
Parts information:
Broken1, the blank cradle you describe is the coin tray mentioned in step 3 above. TrackJunkie, if you have the rubber tray you don't have the cradle/eject box and will need to do the above steps. The adapter costs about $130. The eject box and trim are probably another $150, judging from my invoice which is in Pounds Sterling.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
