Need help: 1st --> 2nd Gear
06-19-2009, 03:48 PM | #1 |
130
Rep 485
My 6MT 335i is around 350 miles.
I still feel the awkwardness of shifting from 1st to 2nd gear. Somehow, it just felt so overly tight to shift into the 2nd gear. Any ideas to improve the technique of shifting from 1st to 2nd would be appreciated. Do I have to lean the shifter more to the left when shifting? Should I press on the clutch a little less deeply? Am I shifting too slowly? what's the optimal way to shift from 1-->2? |
06-19-2009, 05:50 PM | #4 |
32
Rep 1,786
You only have 350 miles,give it a chance to break in and lossen up a little.Also try shifting at higher rpm,s that you are shifting out now.Your not going to any damage as far as the break in mode.
06-19-2009, 06:13 PM | #5 |
Rep 84
2nd gear will always be notchy on this transmission. you'll just have to get used to it. however, I have heard that changing your transmission fluid to royal purple synchro max helps a bit.
06-19-2009, 06:56 PM | #7 |
153
Rep 5,780
CDV does not change the gear engagement, just the clutch engagement. Once the clutch is in, there is no difference if the CDV is in there or not.
OP: as mentioned, the 1 - 2 shift is always a bit notchy on this transmission but will loosed up with time. |
06-19-2009, 07:04 PM | #8 |
Corporate Hack
Rep 288
1 to 2 is a bit notchy, but I have shifted through much worse. What bothers me is that my clutch can make a clunking noise durring disengagement 1 to 2. That pisses me off. Anyone else get this?
New Car: 2008 335xi Coupe
Earlier Car: 2004 STi (got stolen) Earlier Earlier Car: 1995 Mustang GT (416 whp and a blown engine) Really Much Earlier Car: 1988 Mazda 626 TURBO |
06-19-2009, 07:27 PM | #9 |
23
Rep 1,179
i have an 09 6MT also, and the shift wasnt as smooth as my 328 6MT .. it'll loosen up in a lil bit -- mine took 1000mi to feel good .. but then again my 328had a couple of hundred miles on it when i got and my 335 only had like 2mi on it when i picked it up.
if the problem continues for a long time, ask your SA to look at SIB 23 01 09 cheers |
06-19-2009, 08:40 PM | #11 | |
18
Rep 429
1) obviously remove the CDV- it's a bad joke. 2) the shift into 2nd gear is always going to be notchy and my guess is that's it's an internal transmissions linkage issue because of the stupidity of putting reverse internal shift rail next to the 1-2 shift rail unlike most MTs 3) Short throw shifters like the BMW SSKs increase shift effort making this notchiness worse not better IME. 4) I've had good luck with the UUC shifter as, while it is a short throw shifter, it also has a special pivot cup that raises the shifter up and corrects the geometry to reduce effort. So you get the short shift and stock effort. This is good. 5) I've poured in royal purple in my trans and it helped a small amount. It's not expensive, easy to put in and I don't see a downside so it's worth doing IMO but don't expect a huge difference (it's slight). 6) Try this as it worked for me: stop the car, rev the engine to 4-5k rpm and rip the shifter fast from first into second and repeat (total 2 times). Then make a mild drag pass and see if it helps at all. This works wonders for me and instantly improves my 1-2 shift. I don't use it much but it was superb at the track. It also proves IMO that there's something wrong internally in the trans.
2014 Audi S5 DSG
2011 335xi Sedan (retired) 2008 335xi Sedan (retired) |
06-19-2009, 09:09 PM | #12 |
128
Rep 2,740
Check this article out:
http://www.waycoolinc.com/z3/essenti...e/shifting.htm Specifically, read the sections titled "GETTING INTO GEAR AT A STOP" and "SHIFTING UP WHILE ACCELERATING".
06-19-2009, 11:52 PM | #13 | |
654
Rep 10,587
I can also recommend one of UUC's stainless weighted shift knobs. big help in banging it into 2nd gear.
06-20-2009, 01:34 PM | #15 |
130
Rep 485
06-20-2009, 01:36 PM | #16 |
60
Rep 2,314
21.5k miles and 1st to 2nd is a bitch. Trust me, the higher the rpm the smoother the shift (2.5k then shift is much nicer). I do not have the CDV mod.
06-20-2009, 01:37 PM | #17 |
60
Rep 2,314
Yes, it makes me nervous for the long haul of this transmission/clutch.
06-20-2009, 01:52 PM | #18 |
296
Rep 1,515
Drives: Ever changing fleet
It shouldn't, both the tranny and the clutch fairly beefy, the trans in particular. It'll take everything an upgraded turbo car will throw at it (with a clutch that'll hold it).
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
06-20-2009, 01:52 PM | #19 | |
130
Rep 485
07-16-2009, 03:56 PM | #20 |
Rep 78
I get clunk noise when go from 1 to 2 on my 09 335i coupe. I feel the noise is from gearbox. It was smooth sometimes.
07-16-2009, 04:36 PM | #21 |
313
Rep 3,262
The gearbox is very tight (and hard to shift) in the break-in period. I liked that feeling though After about 2500km, it loosens up and you can shift quicker.
But you will truly shift quicker after you install a Short Shift Kit (I have the BMW Performance SSK). After the SSK install, I found out that the shift knob also plays a role in how well you shift. I now have a spherical leather wrapped knob (Momo Race) and the shift is definitely faster but still not ideal (I had the M Sport knob before and it's not a good match for the BMW SSK, in fact its not a good match for anything because it has steep edges). I can shift faster, but not smoother. I guess after removing the CDV things will further improve, but I for one am pleased for the time being.
