Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > More Unknown BT Tool Codes
      06-18-2009, 12:08 AM   #1
Tuned335i
24
Drives: E92 335i
Talking More Unknown BT Tool Codes
Here are three that I searched on and could not find explanations:
N54 Codes
2F4C
2F4C Message EWS-DME digital motor electronics electronic vehicle immobilization-digital electronics failure
Error will not cause a warning light
Error is not currently present
Test conditions have been completed
Signal or value below threshold
2F4A
2F4A Interface EWS-DME electronic vehicle immobilization / digital motor electronics
Car Access System (CAS) Codes
A10A
EWS4 timing challenge / response error
There are two unresolved posts about the A10A code. I've passed these on to Mr. 5 for addition to the master list. Car is running great, no issues.
Torque - The One You Love...
      06-18-2009, 02:17 PM   #2
645Nm
only in it for the torque - awuleth'umshini wami
645Nm's Avatar
South Africa
50
Drives: sapphire black 335i
2009 335i sedan  [0.00]
2005 120D  [0.00]
2007 335i sedan  [0.00]
Unknown and weird to me also.
But glad car is running well!
      06-26-2009, 03:32 AM   #3
Tuned335i
24
Drives: E92 335i
****UPDATE****
I scanned the car after driving for a bit and I get no codes whatsoever. This leads me to believe that the codes I listed above are related to disconnecting the ECU connectors accidentally before disconnecting the battery.
      06-26-2009, 01:13 PM   #4
645Nm
645Nm's Avatar
South Africa
50
2005 120D  [0.00]
Originally Posted by Tuned335i View Post
****UPDATE****
I was hoping you would return to the post...
I got the car access code (A1OA) a day ago. Just try something...keep the door/s or window/s or sunroof open while doing the BT scan and you will get the funny access code. But not when everything is shut. Anyway interesting.
I think you might be right about the other two DME/ECU codes.
      06-27-2009, 02:26 PM   #5
Tuned335i
24
Drives: E92 335i
Interesting!! That's the great thing about E90Post, everybody working through these weird problems. Strange though, I always have the door open when I use the BT Tool and I didn't get the A10A code...
      06-27-2009, 02:56 PM   #6
mid-corner fun
81
Drives: F80 M3, '22 X3MC
Every single time I've scanned with the BT cable is with the windows and sunroof open, cable usually going through the window or through the sunroof on laptop on top of the car. Never seen that code.
You're scanning with ignition on/engine off, right?
      06-27-2009, 03:11 PM   #7
645Nm
645Nm's Avatar
South Africa
50
2005 120D  [0.00]
Yes. Ignition on/engine off.
Perhaps just one of those things.
