06-10-2009, 11:33 PM | #1 |
12
Rep 148
Oil reset
Took the car to the dealer for idle valve replacement and also asked them to do 2nd inspection as only 3000 miles left anyway. They forgot to reset the computer, went back next day and they performed reset procedure only by pushing some buttons. Anybody knows the procedure for resetting oil change?
2012 525d xDrive
06-11-2009, 12:09 AM | #2 |
258
Rep 5,012
Excellent find man. That was one of the things I hate about BMW; all other cars I've owned allow me to reset the computer myself. It was about time. Somebody has to know this sooner or later. I have 3 years and 11 months left to find out . Subscribed. Take care.
06-12-2009, 10:41 PM | #3 |
12
Rep 148
found this, not tested, if you can test pls post results:
PROCEDURE TO VIEW OR RESET SERVICE ITEMS IN THE INSTRUMENT CLUSTER E90, E91, E92, E60, E61, E63 AND E64 1. Turn ignition to Terminal 15. 2. Press and hold the Instrument Cluster Set/Reset button for 10 seconds. 3. The upper display in the Instrument Cluster will be illuminated with a Service Item (example: An oil can is the designation for Oil Service). The lower display in the Instrument Cluster will indicate the remaining time or mileage left for that Service Item (example: 14000). Pressing the button repeatedly will allow the display to scroll through all of the Condition Based Service Items. 4. Press and hold the Instrument Cluster Set/Reset button again and the lower display screen will indicate "OK" or "DUE". 5. Pressing the Instrument Cluster Set/Reset button again will allow the "RESET" to appear in the lower window for that service. Releasing and reapplying the button one more time will reset the service displayed in the upper window only. Repeat the procedure for any additional service reset needs.
2012 525d xDrive
06-13-2009, 12:03 AM | #4 | |
258
Rep 5,012
And what button are they referring to? The one to reset the tripmeter, or the one at the end of the turn signal stalk? Germans . Thanks man. |
06-13-2009, 01:25 AM | #5 |
12
Rep 148
dn't know. original text was in english, it's not a translation. asked same questions myself, will post the reply once i'll get it. i assume is the left stick though, where you reset fuel consumption. will check this weekend.
2012 525d xDrive
06-14-2009, 03:15 AM | #7 |
Just another peanut in the Turd!
92
Rep 598
You can force an OIL analysis/reading by going to the oil selection and holding in the button on the column for 5 seconds.
06-14-2009, 08:05 PM | #8 | |
258
Rep 5,012
Hey Doru, keep us posted man. And thank you for the clarification on the ignition ON issue . |
