what happened to the ducts on LCI
06-04-2009, 08:52 AM | #1 |
258
Rep 3,815
just been looking round the car (e90 LCI m Sport)
having finally got few minutes and I'm schockled to discover the cooling ducts that I had in my e46 m sport for the front brakes are no longer there. What gives. Looking at the front trim of the m sport bumper the grills next to fog lights seem to have some soft plastic behind them. On top the wheel arch looks like has an area marked to be cut out to put ducts in but they are simply not there Can anyone shed some light on this, be a bit annoying if they are no longer available looking at real oem it has a page with the ducts so looks like its only fitted standard to higher end cars (another cost cutting step) http://www.realoem.com/bmw/showparts...50&hg=51&fg=75 Any ideas which parts I need to retro fit as its not clear Last edited by magic77; 06-04-2009 at 11:47 AM.. |
06-04-2009, 09:34 AM | #4 |
258
Rep 3,815
thats the thing I think only the top range get them as having only a 320D its not there looking on real oem they only get listed for 335i and 335d but not sure which bits I need
looking at real oem http://www.realoem.com/bmw/showparts...50&hg=51&fg=75 it states items 1 and 4 but I cant work it out if this is only bits I need 01 FRONT LEFT BRAKE AIR DUCT -M- 1 09/2008 51747891379 01 FRONT RIGHT BRAKE AIR DUCT -M- 1 09/2008 51747891380 04 FRONT LEFT BRAKE AIR DUCT 1 09/2008 51747138413 04 FRONT RIGHT BRAKE AIR DUCT 1 09/2008 51747138414 Last edited by magic77; 06-04-2009 at 09:53 AM.. |
06-04-2009, 10:08 AM | #5 |
1399
Rep 8,083
Do you find your brakes overheat a lot then?
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
06-04-2009, 10:43 AM | #6 |
258
Rep 3,815
not right now but with the track days I'm planning I want them in place before hand, as I said had them on the e46 and they helped a lot
06-04-2009, 11:07 AM | #7 |
Moderator
324
Rep 5,493
there are no brake ducts on the 320d - BMW don't think they are necessary. I can't remember whether the wheel arch liner has a cutout available for the brake duct. You will need to buy two spare plastic brake ducts for a 335d with the same bumper as yours, then pull your bumper off and retrofit these two plastic ducts. You will also have to cut a hole in the wheelarch liner to fit. This will direct cool air into the wheelwell, and help cool your brakes.
However, the ultimate brake cooling kit is to duct straight into the centre of the inner hub, so that air can be expelled out through the vanes of the brake discs! Expensive to do though...!!
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
06-04-2009, 11:13 AM | #8 |
258
Rep 3,815
looking at the wheel arch liner its got the markings where the vent hole should be so easy enough job for a dremel.
Any ideas exactly which part numbers do I need for the ducts as I should be able to pull the wheel liner off and work from inside otherwise will have to work out how to get the bumper off
F30 335i M Sport - now departed
06-04-2009, 11:48 AM | #10 |
258
Rep 3,815
must be an LCI thing - just need to work out if the those part numbers are correct and how much its going to be, its a good thing to have as I discovered round the ring and in the black forrest when chasing bikers
06-04-2009, 11:51 AM | #11 |
258
Rep 3,815
Emailed my local dealer and seems there is no reason why they would not fit.
So all ordered up annoyingly want arrive until at least a week, so will have to wait till later to fit as will get "shot " if caught modding this one
06-04-2009, 12:20 PM | #12 |
Defected to the dark side.....
210
Rep 5,795
Drives: BMW M5 LCi
LCi models seem to lose afew goodies - even on the high end model!!
Mine has NO torch (they had already removed the rechargeable torch and replaced with a small AAA battery powered maglite style one), NO cooled/heated cupholder in the armrest and they have even stopped putting the leather ipod holster in the armrest even with the 6FL option fitted All these were fitted in the lesser model E93 I had! Tight buggers |
