The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Light flickering
      05-29-2009, 06:16 PM   #1
A990
Drives: E90 LCI
Light flickering
Hi Guys,
Did a Xenon retrofit to a halo car the Hid's turn on but as soon as you turn the engine on they flicker the right side will shut off and the driver side flicker ....
The High beam seem to work okay with engine running...
Any Ideas what could be wrong here....
Thanks,
/A
      05-29-2009, 10:20 PM   #2
JayKay335i
Egypt
189
Drives: ///M323 DCT
Voltage issues?
      05-30-2009, 03:17 AM   #3
A990
Drives: E90 LCI
Probably but the car is 09 model & high beams work fine its just the low beam that flickers like a strobe light and the relay on the harness is buzzing all the time...
Originally Posted by JayKay335i View Post
Voltage issues?
      05-30-2009, 08:35 AM   #4
fdiprete
fdiprete's Avatar
21
Drives: 2014 512i xdrive
sounds like a voltage problem, as in not enough, and drawing more current than the harness/relay/car is designed to provide.
      05-30-2009, 09:44 AM   #5
A990
Drives: E90 LCI
Hi maybe but they work fine once the car is switched off... as soon as i start the engine all hell breaks loose....
      06-01-2009, 04:40 PM   #6
HighVoltage
HighVoltage's Avatar
32
Drives: 07 E90 335i
You mean the inner halogen bulbs (Flash to pass) work fine but the new Xenon Hi/Lo (bi-xenon) are flickering? As I recall, a car originally coded with all factory Halogen lights used a square wave pulse to regulate the voltage. This would produce a flicker if hooked directly to a Xenon system with no modification(s). The flickering will quickly derate the Xenon bulbs and cause a failure. Did you reflash the car for Xenons or did this retrofit include some kind of capacitive filter?
