jb3 gas pedal switching with rixster gauge switching
05-22-2009, 09:22 PM | #1 |
122
Rep 1,369
i have rixster vent gauge with boost control..
if i have the gauge set to the default bc.2 and then use the gas pedal switching to map 5 will the car always stay at map 5 or default to whatever bc.2 is??
05-23-2009, 02:40 AM | #2 |
161
Rep 7,377
which JB3 maps are you running? there is a special 1.3 map out on N54tech for download just for the Rixster.
But yes if BC2 is the pedal map switch that when set it will always keep it saved there.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
05-23-2009, 09:42 AM | #3 | |
274
Rep 6,510
-Rick Terry posted the latest 1.3 software with instructions for the rixeffects gauge here: http://www.n54tech.com/forums/showthread.php?t=4039 Last edited by RiXst3r; 05-23-2009 at 10:51 AM.. |
05-23-2009, 11:00 AM | #4 | |
122
Rep 1,369
05-23-2009, 11:01 AM | #5 | |
25
Rep 941
05-23-2009, 11:38 AM | #6 |
161
Rep 7,377
Nothing happens since pedal map switching is on BC2.. wont work on BC1
05-23-2009, 01:38 PM | #7 |
Rep 177
If you want to be able to switch maps with 1.3 on rix gauge you have to DL the hex file that Terry has on his site. However you can use the 1.3 without the update on bc.2 for gas pedal switching. I just keep it on bc.2 and use the gas pedal switching.
05-23-2009, 03:31 PM | #8 |
122
Rep 1,369
i should have said in the first post that i do have the latest 1.3 with rixster gauge enabled
