DIY- Rear Fog Lights
08-08-2006, 07:33 AM | #1 |
14
Rep 17
US cars can have the rear foglights enabled by replacing the light switch with the Euro version. These are the same lamps already installed as adaptive brake lights. While the rear fogs are switched on, the adaptive brake light function is disabled.
Parts required- 61 31 6 932 796 Switch Tools required- flat blade suitable for prying trim pieces First remove the trim piece with AC vent directly above the light switch. I found it was easier to start on the inner end near the speedo. Here what it looks like after removal. This shows the clips that hold the trim in place Now pry out the light switch with its trim piece. Remove the cable by rotating the connector clamp. Remove the trim by pressing in on the clips and move the trim to the new switch. Re-install the switch and trim pieces and you're ready to test. The rear fogs can be switched on only when the fronts are on. These lights are very bright (21 watt halogen) and can be very annoying to drivers behind you, especially at night in clear visibilty conditions. Apparently BMWNA thought US drivers couldn't be trusted to use these lights responsibly. Let's prove them wrong. Last edited by brianlay; 08-08-2006 at 03:46 PM.. |
08-08-2006, 08:44 AM | #2 |
Moderator
318
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
Hang on, just to be clear...all we need to activate the rear fogs is just the switch? That's it? Is this part easily obtainable (not special order etc). GB anyone? So with the rear fogs off, we still have adaptive braking lights, right?
Could we have more pics of installing the actual switch, its not illustrated enough. Is it just plug in, plug out. Awesome find! Awesome DIY!! P.S. Admin please add to Master DIY list. Thanks
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
Wicked_BMW0.00 |
08-08-2006, 09:12 AM | #3 |
252
Rep 6,664
Yeah this is awesome. I had the rear fog light on my A4, and thought it was a very good idea for dense fog. It definitely saved my ass several times. Literally... Called a bunch of dealers and this part is on backorder and not easily obtainable. If anyone has luck please contact me. Thanks..
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER. |
08-08-2006, 09:14 AM | #4 |
Moderator
318
Rep 17,767
Josh: I am also interested in this mod for the reasons you mentioned. Do you know how much the part is? Maybe we can get some sort of GB going, it looks like a relatively easy euro mod....
08-08-2006, 09:28 AM | #5 | |
252
Rep 6,664
08-08-2006, 09:50 AM | #6 |
Moderator
318
Rep 17,767
Thanks Josh, gonna ask around, as well. $75 is not too bad, considering the safety value.
08-08-2006, 10:05 AM | #7 |
Commander in Chief
37
Rep 1,034
Good work!
This is the first truly useful lighting modification I have seen on this site. I think the mods on my car will be limited to your DIY and a set of Euro taillights (I don't like the look of the blacklines).
2008 BMW 535i Space Gray, Black Leather, Dark Bamboo Trim| Sport Automatic with Paddles | Sport Package
2008 BMW M5 (gone, but not forgotten) Space Gray, Silverstone Merino Leather, Madeira Walnut Wood Trim | 7speed SMG | All options Mods: Corsa Exhaust | RPI Ram Air Intake | H&R Sport Springs | Rogue Engineering 12mm spacers |
08-08-2006, 11:28 AM | #9 | |
Moderator
318
Rep 17,767
08-08-2006, 12:17 PM | #10 |
199
Rep 4,178
Drives: E90 325i, E82 135i
Sweet, if you guys get a GB together I am down for that! I am really big on Lighting mods! Lights change the WHOLE look of a car!
08-08-2006, 12:58 PM | #11 | |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
Scroll down to see differences. I used yellow as an example but you can do more colors. And yes mine are still white. http://www.e90post.com/forums/showth...=pics+door+led
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
08-08-2006, 01:07 PM | #12 | |
199
Rep 4,178
08-08-2006, 02:02 PM | #13 |
517
Rep 18,858
Are there supposed to be pictures with the DIY??? I dont see them if they are...
I would also like to do this mod if we can find the part. Let me just make sure of something as well... If this mod is done, does that mean that adaptive braking is not available all together, or just not when the rear fogs are in use??? |
08-08-2006, 02:06 PM | #14 | |
Moderator
318
Rep 17,767
this is what brianlay posted in his other rear fog light thread: "it uses the same lamps as the adaptive brake lights so the look is the same. also, when they are on it overides adaptive brake lights...so says the manual." So whadya say, another group install?
08-08-2006, 02:07 PM | #15 | |
Got Seoul?
116
Rep 2,862
[SIGPIC][/SIGPIC] |
08-08-2006, 03:20 PM | #16 | |
517
Rep 18,858
Sounds good to me... I just dont want to lose functionality of the adaptive brake lights when they are not on... |
08-08-2006, 03:22 PM | #17 |
Moderator
318
Rep 17,767
AJ, could you do some groundwork and check your usual supply sources for that part? Maybe get a small local GB going? Then we can do a group install...looks sorta doable...
08-08-2006, 03:33 PM | #18 | |
517
Rep 18,858
I still dont see those pictures... Do we have a PN??? I can do some investigative research, and use my cca discount to get us a decent deal... BMW of Sterling Parts Department knows me by name now... |
08-08-2006, 06:24 PM | #19 |
I want to drive a Zamboni
1128
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
Nice write up Brian, I will send the request to Morristown BMW for a quote and will keep everyone posted.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
08-08-2006, 07:09 PM | #20 | |
252
Rep 6,664
Josh
08-08-2006, 07:48 PM | #22 | |
Moderator
318
Rep 17,767
