05-21-2009, 09:42 AM | #1 |
121
Rep 1,198
will 285/35 and 305/35 work on TR Motorsport 18x10?
Hi all,
looking for tires to go on my TR Motorsport rims (18x10 25et) and am considering the Nitto NT555II in the 285/35/18 and 305/35/18 sizes. This setup is close to stock in terms of overall height thus my interest. I'm also running eibach pro springs and dinan camber plates with approx. 2 degrees of negative camber. Any thoughts? BC
'15 M3, '16 911 Turbo S Cab
05-21-2009, 12:29 PM | #2 |
1570
Rep 8,075
Drives: 11 E90 M3 Individual
I think a 10.5" wide wheel will work better with a 305 rear. I'd consider going with a square setup.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
05-22-2009, 10:04 AM | #4 |
83
Rep 629
305 on a 10" rim is just too much, most likely will not even fit at all. The max is 285 I would recommend. I do run 285 on a 10"rim but was thinking even that is too much. You don't want to aproach the theoretical limit of the rim, rather choose a tire which is realatively small for the rim. You will not put that much more rubber down anyway. 305 on 10" is not the same than 305 on a 11" rim as contact patch concern. I would definately shy away to overtire my rims on the front. Your steering will not love it.
05-22-2009, 04:15 PM | #6 |
374
Rep 8,033
There you go. That is pretty much the ideal tire size for a 10" rim. Turner runs the 275mm tire and 10" rim square setup on his M3.
