Iphone
05-21-2009, 12:43 AM | #1 |
13
Rep 136
Iphone
I was thinking of finally getting an Iphone , i was just wondering , i have the Ipod connect in the arm rest and bluetooth. can i just plug it in the ipod connect and play music and still get calls?
or how does it work? |
05-21-2009, 12:48 AM | #2 |
77
Rep 1,208
Calls are handled by Bluetooth.
The iPod connection in the arm rest will allow you to use the iPhone like an iPod. The handling of calls vs playing music is done by the iPhone software. It'll fade out the song you're listening to and play the ringtone instead. You can then answer it using the Bluetooth. To change tracks on your iPhone, you use the iDrive controller and select External Device. The iDrive just acts as a controller. |
05-21-2009, 12:49 AM | #3 |
15
Rep 445
Yes, you can. iPhone is not the best phone to be used over BT, though - there are issues like poor sound quality, echo and phonebook transfer problems. Other phone models are known to have scored much better in all respects.
05-21-2009, 12:52 AM | #4 |
13
Rep 136
well im not running Idrive , and at the moment i have a HTC tilt had the phone for a while and was figguring might as well get and ipod and phone = iphone . should i get an iphone for $200 or get an intake for $200?????
05-21-2009, 03:23 AM | #5 | |
15
Rep 445
Have to add that you will have wasted $200 if you get an intake as well. You car already has a pretty good one. |
05-21-2009, 03:32 AM | #6 |
BMW Noob
35
Rep 482
BT works better with Blackberry
Black/White Roundels, CF Interior trim, Blackline, Matte Black Grille, CF OEM Front Splitter, CF Mirror cover, M3 Spoiler, Alufelgen CSL Gunmetal, KW V1, 55% Tint all around http://www.e90post.com/forums/showthread.php?t=257325 |
05-21-2009, 02:56 PM | #7 |
Rep 110
I'm confused as my bluetooth works PERFECTLY with my 1st generation Iphone. I used to have an issue which required me to turn OFF WIFI on my iphone, but that is no longer the case with the last few firmware udpates.
'07 335i Coupe 6MT
05-21-2009, 04:19 PM | #8 |
11
Rep 95
Just to add another perspective. I have an iPhone 3G and it's Bluetooth functionality has been flawless with my 09 335i as well as my previous 07 335i. I would say it works at least as well as my Blackberry Curve did with the 07.
Now on the other hand, the iPod integration is frustrating. It sometimes download song info, sometimes does not. Same deal with charging -- sometimes it works, sometimes it doesn't. But as a phone it's worked fine!
Jim D.
2015 X3 xdrive28d Black Sapphire Metallic/Black Nevada/xLine, Cold Weather, DHP, DA, DA+ w/ACC, Lighting, Premium, NAV, HK Audio, Parking Assistant, Enhanced BT Previous BMWs: 2000 528i, 2003 540i, 2007 335i Sedan, 2009 335i Sedan, 2012 X3 xDrive35i |
05-21-2009, 06:30 PM | #9 |
The Man
17
Rep 348
My iphone works perfectly w/ my car. Recommend it.
2007 328i (01/07 Production)
Monaco Blue / 2014 MSport 328i - Glacier Silver Modifications: Blacked out Kidney Grill || Bluetooth Retrofit || Ipod Retrofit || Rear Power Outlets || Euro Switch || Blacklines |
05-21-2009, 08:44 PM | #11 | |
39
Rep 2,213
Also, my iPhone has worked perfectly over BT in my 07 335i. Would definitely hold off for a few months though, probably 80% chance that a new model will come out here shortly when they release the new version of the software.
Current: 07 335i e90 Previous: 09 Acura TSX PWP Tech Previous: 07 335i e90 with L.E.T. Flash |
05-21-2009, 09:00 PM | #12 | |
46
Rep 2,653
http://www.theregister.co.uk/2009/05..._iphone_rumor/
'07 E92 335i |Crimson Red|Saddle|ZSP|ZPP|PDC|Heated|Logic|Step|Paddles| Mods |Painted Kidneys|Black Lower Mesh Grills|Rho-plate|7500 GP Fogs|JB3 2.0|LED Tag Lights|Rear Fogs|And maybe some day an M3 Rear Spoiler| |
05-21-2009, 09:37 PM | #13 |
Rep 48
I have an iPhone 3G and an '06 E90, and the bluetooth stuff has worked great, no problems.
The '09 X5 loaner I had last week, on the other hand, wouldn't recognize my phone at all. |
05-21-2009, 09:41 PM | #14 |
25
Rep 941
my iphone works perfectly as well, both as a phone and as an ipod. Only problem was getting it to play podcasts. I have to start the podcast, then hook up the phone. Then it works great!
05-21-2009, 09:45 PM | #15 | |
Rep 48
Also, if you have the iPod controller, there's a distinct chance that Apple, in their infinite wisdom, will change the dock spec in the new phone so it won't work perfectly with the car until/unless BMW releases an update... |
05-22-2009, 12:40 PM | #16 |
Rep 272
I say also wait for the new hardware that will be anounced on June 8th. But if you want to get one cheap u can get a refurbished 8gb for 100 from AT&T.
The iPhone works awsome win my e90 non idrive Bluetooth. I use the Kensington aux kit. |
