JB3 Install Help
05-18-2009, 05:48 PM | #1 |
Rep 101
JB3 Install Help
Ok so i am pretty sure i have everything hooked up right. But i ran into a few problems.
I CAN NOT get the slider clips back in are these completely necessary???? Also when i hooked the last wire back up the car started buzzing under the engine bay??? I left the car sleep for 20 minutes and my key is nowhere near the car. Hope i didnt Fck nothing up |
05-18-2009, 06:01 PM | #3 |
Rep 101
well yeah i notices that one was not plugged in right so i fixed it and the noise went away. All noises are gone all the wires are plugged up and tight. As long as you absoluteley do not need the sliders in i will try to drive it
05-18-2009, 06:26 PM | #4 |
108
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
the sliders that go on the plastic harness? yes they should slide and clip in all the way. If they don't then you have a wire in the way, maybe loose or something.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
05-18-2009, 06:27 PM | #5 |
35
Rep 1,202
???The sliders hold and lock the connecters to the ECU. You NEED the sliders. Well I guess it will probably run for a little while but I would think over time the connectors would work them selves loose. Only one slider needed to come off, the smaller one.
no sig.
05-18-2009, 06:55 PM | #6 |
Professional Moose Racer
316
Rep 7,509
Make sure the arrow points in, disconnect the battery!
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1 |HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM |
05-19-2009, 10:12 AM | #8 |
Rep 101
haha so i broke a recrord and it only took my dumbass 3 hours to install. lol. This in nobodys fault but mine. I read into it way more than it was. One simple phone call to mike ( i love you mike!!) and everything was good to go. I mean i just had the entire ecu pulled apart and my car wouldnt start.....no reason to panic right???? lol
as far as the jb3 goes.....HOTT DAMN!!!! lol. I cant wait to try map 5. |
