Bavarian Scanner Help plz..
05-17-2009, 01:59 PM | #1 |
PuffPuffPass
52
Rep 1,096
Hi i just got my scanner last night and I scanned my car and few codes showed up so i did the clear all fault codes option. And than i scanned the car again and it showed up the same codes. I also looked at the imformation tab on the program and where it saids registered VIn it doesnt show anything. Do i need to activate the vin number? The car finds the vin at first when i boot the software and i press ok. Any help would be nice. And by means 3 vin per cable how can i register the vins.
This is what i did. Pluged the cable in computer and car, than press the start ignition button without the brakes pedal so i get a ! mark on dashboard. Than i start the BT program and than it finds my vin # thani poress ok and choose the detected engine MSD80/81 than i press simple test than delete all fault codes..Codes are not seeming to delete when i rescan i get those codes back. Does just plugging in the cord activate the 1 vin usage or do you need to activate it somehow in order to delete the codes. Thanks
My right foot weighs more than my left for sure. |
05-17-2009, 03:28 PM | #3 |
82
Rep 1,389
Some codes are persistent, meaning that just because you cleared the code, it didn't clear the problem that caused the code. Therefore it will poop right back up.
As ^^^ said, what codes are you getting, and equally as important, what are your mods?
"SYONRA" is for sale! http://www.e90post.com/forums/showthread.php?t=366678 BSM '09 e92 335i | Performance: JB3, RR Catted DP's, INJEN DCI, Britalman Exhst, AA FMIC, FORGE DVs | Suspension: ST-V1 Coils, Hotchkis Chassis Brace & F/R Sways | Wheels: Bremmer Kraft BR03s, Brake Performance Rotors, Cool Carbon Pads, ECS Lines | Exterior: OEM Aero Lip/Rear, ****** CF Trunk Lid, BLUX5 Angels, M-Force M3 Sides | Interior: Passport 9500ci, Black Trim, M3 Wheel
05-24-2009, 03:43 PM | #4 |
PuffPuffPass
52
Rep 1,096
These are the codes its throwing and the 30ff code is throwing at 2800 RPM...
Mods are JB3 and DCI. Car runs fine other than limp modes being thrown once a while at low rpm in 4th gear i think. 30FF 30FF Exhaust fume turbo charger, low pressure side Error will not cause a warning light Error is not currently present Test conditions have been completed -------------------------------------------------------------------------------- Fuel pump Longitudinal mgmt Power steering Transmission Stability control Current Fault Codes -------------------------------------------------------------------------------- 5EBA Steering angle sensor: Steering angle-signal only relative. Wheel-center position unknown. Learned quadrant active,(turn onto end position). Or steering wheel signal invalid, or steering wheel-status error Error will cause a warning light Error is not currently present Test conditions have been completed -------------------------------------------------------------------------------- Transfer case Air conditioner Footwell module (FRM) Car Access System Junction box Instrument cluster Rain / light sensor Telematic Airbags Roof control Seat module - driver Radio Current Fault Codes -------------------------------------------------------------------------------- ABEC Error in connection from radio to diversity - wrong antenna or diversity connected Error will not cause a warning light Error is not currently present Test conditions have been completed Also anyone know how to delete the service engine sign? Thanks
My right foot weighs more than my left for sure. Last edited by exidisjon; 05-24-2009 at 04:02 PM.. |
