Any thought on the lifespan of the 335s Twin Turbo Engine?
08-04-2006, 06:06 PM | #1 |
Rep 32
I hope to own my car for a very long time.
Yet I recall reading somewhere that turbo engines don't tend to last for as many miles as non-turbos. Thoughts and opinions on the 335i's potential lifespan vs. that of the non-turbo 328i are most welcome... Thanks, BimmerDreamerFL |
08-04-2006, 06:33 PM | #2 |
11
Rep 613
My guess is forever. I can't see this engine under normal usage dying in just a couple of years. It's like anything else... take care of the car and it'll take care of you.
Edit: I owned a chipped 1.8T A4 and I drove it hard. I never had a problem with the engine. It never burned oil, never. I put 60k miles on it before I lost it. |
08-04-2006, 06:34 PM | #3 |
156
Rep 10,411
minimum 150k if properly maintained
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
08-04-2006, 11:04 PM | #4 |
13
Rep 258
Drives: E92 335i Le Mans Blue
turbo timer?
Is it possible to install a turbo timer on this? Is this turbo even oil cooled?
08-05-2006, 12:02 AM | #6 | |
Rep 32
The 335 turbo engine has run the dyno for 250,000 miles nonstop. But there was no ,, on off on off for the turbo. I will let mine cool when shutting down. You would think with all this technology that BMW would let the car run for 90 sec after key is remove to shut down turbos correctly. |
08-05-2006, 01:27 AM | #7 | |
447
Rep 447
2020 M2 CS AW 6-spd
Previous M Cars: M2C, M2, F80 M3, E46 M3, Z3M Coupe, E36 M3...and some other fun rides. |
08-05-2006, 08:18 AM | #8 | |
11
Rep 613
08-05-2006, 10:49 AM | #9 |
Torque junky
115
Rep 1,688
Drives: Remapped e90 330d
The vast majority of cars on the road in this part of the world are turbo diesels and, while there were a few reported cases of turbos failing a decade or so ago, I know of many TDs that go beyond 200,000km with no problem. In fact, I personally don't know of anybody that's had turbo problems.
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
08-05-2006, 11:00 AM | #10 |
Absolute0
168
Rep 5,078
turbos last a long time with proper care. Which means that if you drive it hard, make sure u give it 1-2 minutes idle of cooling when parking. Otherwise, synthetic oil is good enough for normal driving and helps prolong the life of the turbos
To procede or not to procede......
08-05-2006, 11:20 AM | #11 |
147
Rep 981
Longer than the the CPO warranty.
Turbo engines get a bad rep, because they tend to be easy to mod to mucho hp and people overstress the engine. I remember talking to the Subaru service rep about the WRX engine. In the main, he had seen nothing to indicate shorter life span. What pissed him off, were 'the kids' that kept modding the cars, then bringing them back with melted pistons that they wanted replacing under warranty. The engine should be fine. At least for 6 years / 100k miles. Time will tell.
2013 M3 (E93) - ZPP/ZCW/DCT
08-05-2006, 11:36 AM | #12 | |
156
Rep 10,411
08-05-2006, 01:19 PM | #13 | |
Rep 369
1. They are heat resistant within the operational window defined:1,050 °C or 1,920 °F. 2. They are small, thus the heat generated is far less than most of the configurations out there. 3. The implication of (1) and (2) is that the turbines will not require extra cooling to prevent metalurgical heat stress. The driver just have to treat it like a regular engine. |
07-18-2013, 03:09 PM | #18 |
3441
Rep 79,211
No reason you can't get this engine to 200K like any other 4 stroke that is properly maintained. Turbo's will always wear sooner then the engine. No need for a turbo timer this car automatically feeds coolant through the turbo's. They are water and oil cooled.
07-18-2013, 03:15 PM | #19 |
456
Rep 6,478
At first I thought someone was asking this question in 2013…then I just realized it was merely a 6 year old thread bump
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
07-18-2013, 03:18 PM | #20 |
3441
Rep 79,211
