Boost gauge recommendations?
05-15-2009, 10:12 PM | #1 |
11
Rep 273
I am looking at getting a boost gauge, but am kind of strapped for cash, so does anyone have any recommendations for a cheaper/functional/accurate boost gauge that is simple to install/remove?
Ive been looking at some gauges, and I get confused as to which gauges need extra "modules" to work. Is there a boostgauge that is simple and doesnt require much extra hardware? It can either be analog or digital, but i prefer psi over bar. any suggestions would be appreciated. thank you |
05-15-2009, 10:33 PM | #2 |
اوليسيس
196
Rep 4,678
BMS.
05-16-2009, 02:09 AM | #3 |
134
Rep 3,132
Doesn't BMS's connect directly to the JB3?
Twinz, I'd keep an eye out for a VEI gauge in the FS section. A member turned vendor (Rixster/RixEffects) used to make a pod/gauge combo that was extremely popular and then came out with something that was even better, thus flooding the market with the old setup. I still use the original VEI setup. Here's one for sale, but you should check to see if he's got the tubing/wires for it as well. http://www.e90post.com/forums/showthread.php?t=246111 If you can find one that came with Rixster's original wiring/tubing kit, install should take you less than 30 minutes. Nothing but disconnecting, reconnecting, and a little bit of crimping.
2018 R35 GT-R Cicio800 | 2007 E92 335i - RB Turbos, TC Kline DA Coils, HPA M3 Suspension, Quaife LSD, Stoptech BBK, JB4, FuelIT, AR Downpipes, RDSport Quads, Stett OC, Helix IC, Volk TE-37, Vorsteiner V-35, OSS Headlights | Retired - 2015 F82 M4
05-16-2009, 08:01 AM | #4 |
274
Rep 6,510
my gauge isn't cheap by any means... but every single person who has bought it has said it is worth every penny or more...
maybe i could do a group buy, and get it a little bit cheaper... |
05-16-2009, 10:42 AM | #5 |
The Stig
31
Rep 1,232
Always thought that was a beautiful looking gauge.
05-16-2009, 10:48 AM | #6 |
Rep 177
05-16-2009, 01:27 PM | #9 |
ocasionally in crisis
52
Rep 2,358
rix“s gauge may be the best looking... if u do not mind looking at a gauge to the lower left where the vent is.
BMS gauge is extremely functional if u have the JB3. since u r strapped for cash the best and cheapest alternative until you go with a great gauge is: 1/ run a vacum T and add an extra vacum line for a mechanical gauge. note this is done at the DV vacum lines (look for the DIY). ...run the vacum line into your cabin thru the steering gromet in the firewall underneath the steering wheel (again see DIY). attach a decent mechanical gauge to the end of the vacum line in your cabin... you are done ! now just keep the gauge underneath your driver“s seat and pull it out when you want to monitor things. this worked well for me for many many months until the BMS gauge came out. note that all of this will probably cost you about 50 bucks. if you understand the simple install it should take about 2 hours max. toughest part is to get the vacum lines off and back on the Ts. (use a hairdryer per the DIY). hope this helps.
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
05-16-2009, 03:43 PM | #10 |
12
Rep 428
Interested in a GB for the rixter boost guage as well. Just one question though, will it work with both tunes, the procede and jb3 and secondly what about compatibility with other/future tunes, jb+, flashes, and what about if the next jb3 goes the flash route with the bt cable?
05-16-2009, 03:47 PM | #11 | |
274
Rep 6,510
