Just installed JB3
05-15-2009, 01:28 AM | #1 |
64
Rep 534
Just installed JB3
The install was quite a breeze except putting back on the ecu cover Install time was about 45 mins including reassembly. I went to put on the filter cover back on and I lost one of the 8mm screws in the engine bay Hopefully I can find a replacement before servicing I left the JB3 on the default map and man, what a difference!! It is way more than I expected. I think I will drive with map 3 for a few days, then try map 4. I don't want to go any higher than that without supporting mods. Any of you guys run higher than 4 with no supporting mods?
05-15-2009, 02:21 AM | #2 |
Professional Moose Racer
316
Rep 7,509
I lost one of my screws too. You better find it quick, I took like a gazillion bolts to get the underpanel off and couldnt find it. All the road shock must have shook it out.
Congratz on the install!
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1 |HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM |
05-15-2009, 02:32 AM | #3 |
749
Rep 2,108
oh yeah lool, dont try them if you dont wish to try the higher maps, cus once u do, you cant go back to anything than map 6 and higher
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
05-15-2009, 04:57 AM | #4 |
Stuntin'.
22
Rep 583
Drives: //Mtrey/K7 GIX600
congrats on the install!!
which version do you have? 1.22v or 1.3v? when i had my 1.22v i drove map 4 and 6 daily. the high rpm pull on map 4 is ridiculous but map 6 is consistent from low rpm throughout the powerband. as for the 1.3v now. very smooth power. i would suggest you upgrade your chip whenever possible. |
05-15-2009, 05:27 AM | #5 |
333
Rep 4,632
Congrats!
Give it some time to adapt and it will get even better! I am guessing your 1.3 offical? What octane/mods do you have other then the JB3? Temps around your area?
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
05-15-2009, 06:58 AM | #6 | |
32
Rep 414
depend of octane you run. For my friend (e93 bone stock) no problem with map #7 on 94oct. On last 1.3 rev4
'08 BMW 335xi // Sedan // Black Sapphire // Sports Package//Mods: JB3 2.0|Unlocked 18ohm Board|BMS Meth Kit|AA Speed Delimiter|BMS tuning gauge|UR CL DP |BMS DCI|AA Exhaust|Helix fmic|CDV|H&R coilover| 10mm Spacers H&R on 4 wheels|**Record for XI's on dragtimes.com, 11.768s@118.70**Top speed 186,4 mph GPS, vbox 60-130mph at 10.18
05-15-2009, 09:00 AM | #8 |
64
Rep 534
I am using the latest version 1.3. Was shipped direct from Terry. I do not have any other supporting mods other than that of the stock oil cooler that came with the sport package. When I started up the car, no CEL came on, although some other funny warnings came up. I got the 4x4 warning indicator, xdrive fail indicator, and brake pad fail indicator. As soon as I drove off, all of them went away. They haven't been back yet. I disconnected the neg term on the batt, and I am not sure if everyone does the same. I unfortunately don't have anything higher than 91 octane here in Calgary besides Mohawk and Husky which have 94, but up to 10% ethanol. I don't trust it after all the crap I have been reading about the HPFP failures. I am 1000 meters above sea level so due to the atmospheric pressure here, I don't think knock will be much of an issue and 91 octane should be fine. I don't think there would be much advantage even if we had 94 octane. I live in Alberta which is one of the world's largest producers of oil and gas, so you would think that stations would be loaded with 94 octane if it did make a difference.
05-15-2009, 09:29 AM | #9 | |
32
Rep 414
91 vs 94 = yes difference...probably 10hp...I think
05-15-2009, 05:25 PM | #12 | |
Rep 83
335i Jet Black/Coral Red JB3 1.3/BMS DCI 64 Lincoln Continental 08 Range Rover Sport |
05-15-2009, 06:47 PM | #15 |
441
Rep 18,331
05-15-2009, 06:55 PM | #16 |
Slow Mo
15
Rep 534
The two biggest things I noticed with the DCI is sound and decreased spool time. Hard to actually feel the extra power.
BMW '17 X5 35i, '15 M4, ED 7/1/14, US 8/4/14, PU 8/18/14, '13 X5 35i, '08 335i
Motorcycles: BMW '12 R1200GS, '10 F800GS, '74 R90S |
05-15-2009, 07:01 PM | #17 |
Rep 83
I have no clue if it does but i just finished installing and took for a quick 0-100 down my local street.. the sound of the turbos = SEX
05-15-2009, 07:06 PM | #18 |
161
Rep 3,736
05-15-2009, 07:29 PM | #19 | |
Anthony
Rep 274
05-15-2009, 08:03 PM | #20 |
**N54 Power Baby**
29
Rep 680
hahaha..congratulations on your newfound power..try the higher maps..I'm on the latest and greatest 1.3 8D Rev 4..been running map 7 daily driven on 93 octane and only DCI..with no problems..car pulls pretty damn hard..try the higher maps..im sure you'll get a hard on.
05-15-2009, 08:38 PM | #21 |
WARRIORS come out to play yay!!
37
Rep 347
Drives: 2016 F30 340i M Sport
JB3=CRACK
2016 340i M Sport/Alpine White/Black Dakota Leather/Ash Wood Trim/ M performance carbon fiber spoiler, M performance grills, M performance front splitter, M performance carbon fiber mirror caps, Llumar ATX Axcess 30% tint
05-15-2009, 09:25 PM | #22 | |
Rep 101
Is this safe? I thought you would have to have more supporting mods to run that high of a map. Mine will be arriving in a few days and all I have is the BMS DCI. We have 93 octane around here what is the highest map i can run? |
