Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Procede installed
      05-15-2009, 01:15 AM   #1
Spike
Autobahn Driver
Spike's Avatar
Germany
15
Drives: M6 Singapore Grey
Procede installed
one year ago i installed my aa active processor in my car. it's a great tune for the n54 enginge. but now it was time to change.
i dont know what i should take. JB3, Procede ore whatever. it was a terrible decision.
now, tataaaaa .... its the procede.
a big "THANK YOU " goes to Robert from Vishnu. for his help and patience. and for the excelent shipping selection and preparartion. only 4 days from california to germany. thats a number.
and now the procede is in my car. it works fine. the adaption is not finished yet but the car is quik - very quik.
at this time i think the power delivery is much smother than with the aa processor.
we will see
lars
M6 - Singapore Grey
      05-15-2009, 08:43 AM   #2
MSPORTWORLD
MSPORTWORLD's Avatar
232
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Congrats and welcome to the club!
What map/user torque are your using?
      05-15-2009, 12:37 PM   #3
Spike
Autobahn Driver
Spike's Avatar
Germany
15
that i must show detailed later.
i put the procede out of the box, put it in the car and drive away
later i must compare the map.
earlier today i establish the connection between procede and my laptop. yesterday i have no usb-serial adapter. now i find an old palm connect usb - serial adapter. and you will not believe it - its fully functional. with windows xp drivers on a vista pc.
then i saw that the ut is 90 by default and the max psi is 16. i think its to mutch for my car setup? i dont know.
M6 - Singapore Grey
      05-15-2009, 02:07 PM   #4
dmurray14
The Stig
dmurray14's Avatar
31
Drives: Quickly
That means you probably have the older 2-19 maps on there. Load up the maps from 4-30 and grin even more
      05-16-2009, 04:00 PM   #5
Spike
Autobahn Driver
Spike's Avatar
Germany
15
hello,
now i have reduce the ut to 70. the car is much slower but i have no misfires. my bt shows much misfires at cylinder 1.
next thuesday my car becomes new spark plugs (the dealer has it not on stock). the old ones runs now ~40.000miles and ~20.000miles with the aa processor. i think i must replace it.
whats your settings of ut, max boost and other things in my config (dci, procede canbus, rest stock)
or whats your recommandation?
thanks
lars
M6 - Singapore Grey
      05-16-2009, 09:17 PM   #6
MSPORTWORLD
232
Try this first: Swap the ignition coil from cylinder 1 to cylinder 2 and then rescan for misfire, if it goes from cylinder 1 to cylinder 2 replace your ignition coil, no need to replace the the spark plugs if its not the issue.
Hope this helps, I had similar problem that I debugged same way: http://www.e90post.com/forums/showthread.php?t=250979
hello,
thanks
lars
      05-22-2009, 04:09 AM   #7
Spike
Autobahn Driver
Spike's Avatar
Germany
15
wednesday i changed the spark plugs. now the car have no misfires, no limps - nothing.
i'm very happy with the procede.
under wet conditions i logged with proscan the following values
60' Time ......... 2,065sec
0-60 MPH ........4,482sec
1/8 Mile Speed..89,367mph (143,8km/h)
1/8 Mile Time ...8,376km/h
1/4 Mile Speed..110,494mph (177,8km/h)
1/4 Mile Time ...12,873sec
i know it is not the fastest. but it was wet and it was my first run. then it began to rain again and i stop my tests.
i ran stage 1 map with ut 90%.
here a 100-200km/h run
M6 - Singapore Grey
      05-22-2009, 07:47 AM   #8
MFKN3
MFKN3's Avatar
Australia
127
Drives: supercharged 4.4L stroker E92
I find the latest 5-08 maps and firmware the best so far. I run stage 1 70% on map 1 and 75% on map 2 for when the weather is cooler. Car pulls like a beast. I haven't data logged yet, so haven't tried pushing it higher but I definately feel an improvement at 75% on a cool evening. I have DCI intake, mid pipes and cat back and use 98RON gas.
You might want to wind back your UT mate as 90% is very high. Default for stage 1 is 70%.
      07-11-2009, 05:41 PM   #9
Spike
Autobahn Driver
Spike's Avatar
Germany
15
today i made a vmax test at the autobahn - yes, in germany we have autobahn
here you can see a video :
(the video is cuted at the end, no visible changes over 280km/h)
the procede has the 123 firmware and i run the stage 1 map with 80% UT. i have logged the speed and the rpm with an obd tool. the speed freezes at 255km/h ... but the rpm was correct. the max rpm at this run was 6970 (it's an at car)
in dependency of scale of tires, gear ratio and axle the max speed was between 307 and 317km/h. thats great ... fantastic
thank you Shiv for this great tune ..... and thank you BMW for this great enginge and car
M6 - Singapore Grey
      07-11-2009, 06:54 PM   #10
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
... 317km/h.
317 km/h = 196.974668 mph
      07-11-2009, 07:02 PM   #11
OpenFlash
1737
Drives: A Lot
New top speed record???
      07-11-2009, 07:35 PM   #12
jaysonbmw
F1
jaysonbmw's Avatar
Drives: Formula 1 E92
Holy crap!!196mph?
      07-11-2009, 08:01 PM   #13
cn555ic
cn555ic's Avatar
441
Drives: 335i
HOLY SHIT 196! OMG thats fast!
      07-11-2009, 08:18 PM   #14
MFKN3
MFKN3's Avatar
Australia
127
Hey man have you datalogged your runs? 90 and 80% UT on stage 1 with DCI is getting up there. Would be pushing 16psi possibly??
      07-11-2009, 10:05 PM   #15
stressdoc
Moderator
stressdoc's Avatar
Dominica
618
Drives: BMW i8; Toy 4runner TRD pro
Autobahn beast!
Make sure you have the proper suspension & tires to handle 300kph+
I have got to do an extended ED -- wonder if German customs would confiscate a Procede...
      07-12-2009, 02:41 AM   #16
munters
munters's Avatar
11
Drives: E91 335XI AT Dakota Black M
but the cool thing is 255 is stored in the ecu. Well done shiv
59 Corvette, 72 240Z, 73 Espada, ZXR
      07-12-2009, 03:17 AM   #17
per
Sweden
47
Drives: M3 E92
Here is a video of my old car, done by the new owner, i wounder what the 0-402m, it looks realy fast
      07-12-2009, 07:12 AM   #18
Spike
Autobahn Driver
Spike's Avatar
Germany
15
maybe - i dont know
more boost is not possible with my car. over ut 80 i become misfires at high rpm.
M6 - Singapore Grey
      07-12-2009, 02:45 PM   #19
OpenFlash
1737
Drives: A Lot
maybe - i dont know
If you are only running dual cones (ie, no exhausts mods), running much-higher-then-default User Torque values can certainly induce misfire. But 80% shouldn't. Try swapping out spark plugs with new ones. That should fix that. Of course, I don't recommend running higher UT until you verify that your octane/conditions can support it. Since u have a Rev.2 with CANbus, that will be easy to do.
Shiv
      07-12-2009, 03:05 PM   #20
Spike
Autobahn Driver
Spike's Avatar
Germany
15
Shiv
i have only dci. the spark plugs are new (~2500miles). with ut 80% all is okay. no misfires. then i run higher ut (85 or 90) the engigne produces misfires at higher rpm on different cylinders. not always but i can wait for. especially at the autobahn with continuously higher rpm (over 4000).
i'm using only ROZ 100 Gas (Shell V-Power). i dont know the comparable gas in u.s.??
M6 - Singapore Grey
      07-12-2009, 03:14 PM   #21
per
Sweden
47
Drives: M3 E92
A friend of mine had the same problem, the solution for him was to change the injektors.
      07-12-2009, 06:05 PM   #22
MFKN3
MFKN3's Avatar
Australia
127
Surely at 80% you'd be seeing 16psi?? I run 75% and sit on 14.5-15psi and wouldn't want to go much higher than that
Shiv, I suppose you mean by safe conditions, you mean datalog a run to see max boost?
