E92 stock exhaust pipes diamater?
05-13-2009, 12:37 AM | #1 |
76
Rep 1,548
Are they 2.25" or 2.36"? I've searched and found those numbers in different threads. I have the 2.5" high flow cats but if the pipes are 2.25" I will need to return them and reorder the right ones before I have the pipes cut. Thanks
05-13-2009, 01:06 PM | #6 |
27
Rep 1,410
which is why most aftermarket stuff in the US is 2.5" so it is slightly bigger (good) and I believe the HKS exhaust is actually 65mm to accomodate all of these 2.5" downpipes.
60 millimeters = 2.36220472 inches 65 millimeters = 2.55905512 inches |
05-14-2009, 08:03 AM | #8 |
153
Rep 5,780
Yes; however, you will need to get a shop to weld them up as 2.5 inch cats are meant to slip onto 2.5 inch ID pipe. In other words, do not expect to use clamps. But I doubt that was the plan anyway.
05-14-2009, 09:55 AM | #9 |
76
Rep 1,548
05-14-2009, 08:37 PM | #10 |
76
Rep 1,548
the high flow 300 cell count cats are welded on but the oem pipes are actually 2.25". Throttle response is better and a lil bit louder. Is it a good idea to run stage 3 even though it's not completely catless? Has anyone tried yet? Anyway, Im gonna try and see how it drives
05-14-2009, 08:44 PM | #11 |
153
Rep 5,780
They are 60mm as that is 2.36. The tenth on an inch difference can be accounted for by variances in wall thicknesses.
On 91 octane, I would leave it at stage 2 IMO. |
05-14-2009, 09:08 PM | #12 |
76
Rep 1,548
we compared the oem pipe end to the 2.25" end and they are exactly the same size. Anyways, I'll try stage 2 as well. Thanks Steve
